Calipers sticking two months after replacing them. - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-02-2010, 05:57 PM Thread Starter
Date registered: Jun 2010
So two months ago i replaced the front calipers on my 78 300d. Just recently my Nuetral safety switch went out and my car sat for about a week. After i fixed the nss i took it for a short spin and noticed the breaks were sticking again! I dont know what could cause this, im hoping someone on here will. Thanks in advance for your time!
abiteofcrime is offline
post #2 of 6 (permalink) Old 07-02-2010, 11:12 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 17 Post(s)
How old is the booster?
http://i30.photobucket.com/albums/c328/nutz4benz/W123/6C3A9CA5-EDFF-4834-8125-34B70B20A676_zpsiyesrawz.jpg
Nutz 4 Benz is offline
post #3 of 6 (permalink) Old 07-05-2010, 12:02 PM Thread Starter
Im not sure honestly. I got this car as sort of a project, mostly just to learn. Is there any way i could test it to see if thats the issue?
post #4 of 6 (permalink) Old 07-05-2010, 01:45 PM
tecrekka's Avatar
Date registered: May 2003
Vehicle: 72 280 SEL 4.5 - 81 VW Rabbit - 85 XJS - 86 XJ6
I don't know if it is the same situation but I recently had my 72 W108 taken in to replace what I thought was a sticking caliper. Turns out it wasn't the caliper at all but a collapsed brake line that would cause the caliper to stick after a few miles, very much like a damaged caliper. Worth checking out I suppose, hope this helps.
1972 280SEL 4.5 W108.068/M117 V8
tecrekka is offline
post #5 of 6 (permalink) Old 07-06-2010, 04:18 AM
Date registered: May 2009
Vehicle: S 600 W 140
brake hoses , traps for young players. this is why the world needs old people...........lol
genthree is offline
post #6 of 6 (permalink) Old 07-06-2010, 07:15 PM
wbain's Avatar
Date registered: Dec 2003
Most likely the flexible brake hoses have collapsed. They need to be replaced. Use penetrating oil on the chassis connections and let the oil soak in and keep reapplying it to the joint. Then use flare tool wrenches, the ones with the slot at the end, and unscrew the pipe from the hose and then the hose from the caliper. The new hoses have a white line on them so you can tell if it's twisted.
Screw in the hose to the caliper and then route the hose to the chassis mount. Screw in the pipe, using your hand so you don't cross thread the pipe, and then tighten with the toool. Replace both sides and the rear one too.
Bleed the brakes with new DOT 3 or 4, 4 is a higher temperature fluid.
wbain is offline
    Replacing calipers Luke1 W116 S, SE, SEL, SD Class 1 02-09-2010 07:54 PM
    Wiper sticking nickCR W202 C-Class 6 11-22-2009 11:11 AM
    Rear Calipers on 1980 300SD Sticking- Wont Contract for pads? Help! 240-John Vintage Mercedes-Benz 6 09-02-2006 07:27 AM
    Speedo sticking Coffs500SL R129 SL-Class 0 03-19-2006 05:51 PM
    White Calipers or Red Calipers on a white slk32? kenny R170 SLK-Class 17 10-21-2001 08:24 AM
