67 250se tranny adj. one question - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 11-07-2011, 12:41 AM
Date registered: Nov 2011
Hi guys, i have w112 300se 1964 my trany use to shift when i let go of the accelerator and it was shifting hard, i removed the transm.. I found that the linke vacume box was jamed. After buting the trany back the trany shift so hard around 45mph and stay at high gear. Any suggestion please
Dubai classic is offline
post #12 of 13 (permalink) Old 11-07-2011, 12:54 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Originally Posted by ktmripper View Post
Govert, That is what I had been told also on the rod, I,ve adjusted the rod almost all the way out at all points with no difference in shifting.
My advice would be to adjust all the rods according to the specs in the FSM. Also check for any worn rubbers in the gas linkage.
Govert70227 is offline
post #13 of 13 (permalink) Old 11-07-2011, 12:58 AM
Thanks sir i will check it out and let you know, regards
    Throttle valve - idle speed stop adj Question Tony Barroso R/C107 SL/SLC Class 40 07-09-2010 06:08 AM
    Camber Adj and Tow Adj Frozen, need help RDM3 W201 190-Class 0 05-01-2010 10:10 AM
    1968 250SE coupe and 1968 250se coupe parts car for sale JJsAtoZatAz@MSN.COM Vintage Mercedes-Benz 4 01-20-2010 09:29 PM
    67 250se/c alternator wiring Question ChopTop250SE Vintage Mercedes-Benz 2 06-20-2009 01:39 AM
