Disassembling Front Upper Control Arm Bushing (w108) - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-01-2010, 07:26 AM Thread Starter
Date registered: Mar 2010
It's that time to replace my control arm bushings on the 70 280SE! And I'm lost on how to disassemble the upper/outer control arm bushings. I got the nut off the bolt and try to: thread it out (seems theres a pin that locates the bolt) to no avail and have tried to hammer the thing out (with the nut on and with a brass hammer) but it doesn't even budge!
Done:
- removed "V" clip
- removed nut
- drenched everything in PB Blast
- Hammered until my arm hurt
What's the deal? The car is a big weathered but the damn thing won't move. Could someone explain how to get the bolt out please!
pic for reference:
I rarely get stuck on things like this but right now I'm at a loss! Any tips would be appreciated!
Ratty111 is offline
post #2 of 6 (permalink) Old 07-01-2010, 11:08 AM
wbain's Avatar
Date registered: Dec 2003
It's simple. Lack of scheduled lubrication has caused the long bolt and the threaded bushing to weld together. You will have to cut the bolt and remove the kingpin. A new kingpin is required.
wbain is offline
post #3 of 6 (permalink) Old 07-01-2010, 11:27 AM Thread Starter
yikes.. you don't believe that some heat and an air hammer would free it?
I do suppose it's time for the king pins to be replaced as well..
Ratty111 is offline
post #4 of 6 (permalink) Old 07-02-2010, 12:25 PM
wbain's Avatar
Do a search for kingpin in this board:
Drive train, fuel, suspension, steering & brakes
Most cars of the 60's use the same front suspensions.
wbain is offline
post #5 of 6 (permalink) Old 07-03-2010, 10:02 AM
Wbain, is correct, saw the bolt off on both sides of the kingpin, chances are good that the slug in the kingpin head will release and be easily removed. I've had to do this a few times. And I have a few spare kingpins if it can't. Check the big holes in the upper A-arm for cracks.
Lube is everything on the old front axle.
Brian O
bostosh is offline
post #6 of 6 (permalink) Old 05-06-2013, 09:25 AM
Date registered: Jul 2012
Vehicle: 1967 250S, twin Weber carbs, automatic trans, power windows, A/C, R134a conversion
The nut comes off and the pin tapped out using a steel drift that's smaller than the bolt diameter. Once out, the centering bushing screws of of the king pin
Kitaka is offline
    Anybody have a upper front right control arm?? vaser21 W140 S-Class 4 06-11-2010 03:10 AM
    Upper transverse control arm front AUTOROYAL W220 S-Class 1 05-09-2010 04:31 AM
    '98 C43 AMG Front Right Upper Control Arm job dlwst44 W202 C36 AMG, C43 AMG 0 11-27-2009 09:30 AM
    Front Lower Control Arm Bushing Replacement mischief W203 C32 AMG, C55 AMG 9 11-04-2009 08:10 AM
    Broken Upper Control Arm Bushing Big D W126 S,SE,SEC,SEL,SD,SDL Class 3 09-07-2005 11:10 AM
