Adjusting vent windows on '72 280 SEL - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-29-2010, 09:16 PM Thread Starter
Date registered: Apr 2009
Vehicle: 1972 Mercedes Benz 280 SEL
Both the drivers side and the passenger side vent windows have wind noise and whistling coming from then. Can they be adjusted to tighten them up? I'd like to know before I start tearing the door panels off.
Packard1807 is offline
post #2 of 5 (permalink) Old 06-29-2010, 11:00 PM
Date registered: Nov 2003
They sure can! You'll find a screw adjustment on a linkage.
E430_4Matic is offline
post #3 of 5 (permalink) Old 07-04-2010, 02:16 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Take off the door panel and you'll see the adjuster. If the linkage is made to be a little longer, the fit will be tighter.
Grubeguy is offline
post #4 of 5 (permalink) Old 11-15-2010, 04:50 PM Thread Starter
Thank you all for your help. My '72 280 SEL is absolutely super. I replaced the heater blower motor, got the clock repaired, refinished all the woodwork, repaired the windshield washer system, replaced the injectors and sensors, and finally figured out what was causing the smoke now and then - valve seals, which also have been replaced. The car now looks and drives like a new car, and it constantly turns heads. As someone who has collected once "out of favor" Packards which have now appreciated nicely, I think the '72 280 SEL will see the same thing happen. I couldn't have done it without the help I received on this board.
post #5 of 5 (permalink) Old 11-15-2010, 10:03 PM
Date registered: Feb 2010
Vehicle: 1968 250SE S-Class. 1988 560SEC S-Class Widebody
Quoted: 39 Post(s)
good work, im keen to see some pictures
D&WCali is offline
    2000 280 Stuck Windows Ron Burns General Mercedes-Benz 3 01-27-2007 10:03 AM
    Adjusting the Idle Speed on a 500 SEL DjigitDaniel W126 S,SE,SEC,SEL,SD,SDL Class 3 12-28-2005 12:09 PM
    SEL Console Vent stuck mramay W126 S,SE,SEC,SEL,SD,SDL Class 1 05-14-2005 09:17 PM
    Powered Rear-quarter Vent Windows JFR W163 M-Class 2 05-04-2003 09:26 PM
    Fuse location for windows of 1976 Mercedes 280 MatterLaw W123 E,CE,D,CD,TD,TE Class 1 08-28-2002 01:00 AM
