How to change oil in a 74 240d - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-27-2010, 09:57 AM Thread Starter
Date registered: Apr 2009
hey yall tryin to change the oil in my 74 240d n not really sure how im very new to mercedes diesels n need some help. ive changed oil on semis and other diesels n trucks but never one of these
JustinRay310 is offline
post #2 of 2 (permalink) Old 06-27-2010, 05:12 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Drain plug on the oil pan is pretty straightforward, use a new copper washer and don't overtorque the plug (30 Nm is about it).
Oil filter can only be removed from underneath. It is on the driver's side of the engine. Clean the microfilter (that is the important filter, as it filters most of the oil) and replace the filter inset. If the microfilter is damaged, replace it. Use a new washer and rubber O ring to put the filter back together again.
For more info: go to this page:
18 Engine Lubrication, Engine Oil Cooling - OM616
and select 18-005, the first five pages are about the 240D you have.
Govert70227 is offline
    1981 240D oil change oil filter assembly ? 50 cool 50 W123 E,CE,D,CD,TD,TE Class 3 04-23-2010 05:54 PM
    82 240D: manual transmision oil change? CrAlt W123 E,CE,D,CD,TD,TE Class 5 05-25-2009 06:08 AM
    Oil Change in 81 240d cause lack of power and lower oil PSI? Cobb2 W123 E,CE,D,CD,TD,TE Class 12 07-15-2008 10:51 PM
    Very dark oil immediately after change ('74 240D) FieroGT42 General Mercedes-Benz 12 06-19-2007 05:33 AM
    '83 240D issues and oil change Synchr0 W123 E,CE,D,CD,TD,TE Class 11 05-30-2006 01:01 PM
