help me w108 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-22-2010, 02:05 PM Thread Starter
Date registered: Jun 2010
help me w108
i have a 1968 280se i am getting no fuel to the engine i know the rear pump is bad and fuel filter is probably clogged need to know where to get a new filter and wanted to replace the rear pump with a universal unit with a regulater i need to know what psi i need to regulate the rear pump to or where to get a rebuild kit for the pump in the tank.
noahmitchum is offline
post #2 of 3 (permalink) Old 06-22-2010, 08:53 PM
wbain's Avatar
Date registered: Dec 2003
These cars use a low pressure fuel pump. The pump can be disassembled, cleaned and repaired, especially the 'long body' pump. There are also screen(s) in the pump intake and the FI pump. Fuel filters are available and are in a housing under the FI pump on the engine support. You must remember, keep everything clean because if any dirt or lint gets into the FI pump, it will cause problems.
I did a search on 'fuel pump', exact phrase minus the quotes in the Fuel Management forum on The International M-100 Group forums.
M-100 Message Board - Long-body pump rebuild
M-100 Message Board - Fuel system cleaning and rebuild on #495
and Welcome - Mercedes Benz 230SL, 250SL, 280SL Pagoda Group is also a good resource because these cars use the same system for fuel injection.
There is no pump in the tank because it's gravity fed to the electric pump. I hope this helps.
wbain is offline
post #3 of 3 (permalink) Old 06-23-2010, 10:04 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
If you go new, the pump will be pricey. I'd be careful about buying used, or something out of a junk yard. There have been a number of discussion threads on this forum regarding using a generic pump, or something off a Ford or Chevy (sorry purists...), but I don't recollect whether that was ever put to bed or not.
The fuel pump is pretty cheap. I paid something like $19 at Kragen. Try also Napa Autoparts, or if you want to shop around, do a general google search for Mercedes W108 parts. You'll find a number of companies that support parts for our old beasts.
Additionally, there's a part of this forum labeled "Online Resources." You might find something useful there regarding your fuel system.
Grubeguy is offline
    HELP!!! 67 w108 won't start!! hugedodge2000 Vintage Mercedes-Benz 6 01-26-2010 10:50 AM
    New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
    Looking for a W108 neemhakim Vintage Mercedes-Benz 3 08-11-2007 06:35 PM
    You here yet w108? Syracuse315 Test 41 01-03-2006 12:28 AM
    W108...what do I need to know? ScottMcG Vintage Mercedes-Benz 8 04-02-2005 11:50 AM
