I need help with my clutch 1967 230s - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-20-2010, 07:55 PM Thread Starter
Date registered: Feb 2010
Vehicle: 1967 230s, 1968 250
Post I need help with my clutch 1967 230s
I was having problem with the clutch padel not returning at times, then at times it will fall down to the floor, then I use my foot to bring it back, and somtimes after driving for period of time the speed of the engine does not catch up with the movement of the car.After it sits for a while ,it starts to drive normal ontill a while then it begins to do the samething again.I change the master and slave cylinder and the hose but stll doing the same. does anybody have an idea about the isue. Thanks
joey-nice is offline
post #2 of 4 (permalink) Old 06-20-2010, 11:19 PM
wbain's Avatar
Date registered: Dec 2003
The clutch hydraulics need to be bled. It needs to be bled from the slave cyl up. either using the front left caliper or using a power bleeder.
wbain is offline
post #3 of 4 (permalink) Old 06-21-2010, 09:38 PM Thread Starter
what is a power bleeder and when you say front left caliper , do you mean the brake caliper.I need some step to step guide lines . Can you help please. thanks
post #4 of 4 (permalink) Old 06-22-2010, 10:00 PM
wbain's Avatar
A power bleeder is an air pressure operated bleeded that has a tank and a hose that screws onto the brake reservoir. The tank is pressurized and the brake caliper bleed screws are opened to allow the brake fluid to flow and remove any air.
The front left caliper is used to send brake fluid from the caliper bleed screw to the clutch slave cylinder bleed screw, up to the clutch mater cylinder and up to the clutch reservoir. You can do it manually by pumping the brake pedal and openeing a closing the slave cylinder bleed scred, but that's a PITA because it requires two people.
You will also need about 6 feet of clear hose.
For example: Motive Products
wbain is offline
    Parting Out W111 Fintail Heckflosse 1967 230S 4 Door Squiggle Dog For Sale/Wanted/Trade/Giveaway 46 04-21-2012 02:47 PM
    1967 230S finny $995-bo (READ ALL) 240D82 For Sale/Wanted/Trade/Giveaway 1 07-16-2008 05:37 PM
    230S Window Channel... tlcdent1 Vintage Mercedes-Benz 0 09-24-2006 10:53 AM
    Anyone looking for 1962 230S project? Michael Pillay For Sale/Wanted/Trade/Giveaway 0 02-20-2006 08:19 AM
    for the early 230s DA_SURG R170 SLK-Class 9 12-27-2005 02:16 PM
