Electric Fuel Pump Q - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-20-2010, 11:46 AM Thread Starter
Date registered: Feb 2010
Vehicle: 1966 250S, 2001 CL55 AMG
I'm testing my electric fuel pump on my 72 4.5. I get fuel to the pump and it switches on with the key so the relay looks good. I'm not getting anything out of the pump. I just took off the outlet from the pump to the filter and gas poured from the opening. The outlet looks to have a spring loaded seat to restrict fuel flow. How does that work? Does the pump build enought pressure to open the valve? Can I replace it with an outlet that doesnt have the valve? Is my pump DOA?
Thanks!
[SIGPIC][SIGPIC]
kenny_amg is offline
post #2 of 2 (permalink) Old 06-20-2010, 08:00 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
This thread has a lot of info on fuel pumps:
http://www.benzworld.org/forums/w116...p-rebuild.html
When you say you get no flow, where did you check it? Flow can be tested by removing hose from outlet of damper downstream of fuel pressure regulator and running it into a container - need to jumper relay so you can run pump for 30 sec and measure amount collected - 1l/30sec is the spec.
Otherwise, maybe remove pump and hook it up so as recirculate kerosene or some no flammable fluid through it.
MBGraham is online now
404 Electric fuel pump dxmedia Unimog 5 05-25-2010 11:33 PM
Electric fuel pump akimball442 W123 E,CE,D,CD,TD,TE Class 9 10-13-2009 04:10 PM
Add electric fuel pump?? kimmer Unimog 4 07-13-2009 07:14 AM
Electric Fuel Pump MR. MUD Unimog 12 04-17-2009 06:26 AM
Electric fuel pump locations? delawaredrew Unimog 20 06-14-2008 08:33 PM
