spark - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-16-2010, 10:07 PM Thread Starter
Date registered: Jun 2010
spark
I have a 1971 250 hats been sitting for the last 15 years. It as given to me and am trying to get it running but it looks like someone added a ignition box to it because it doesn't show up in my book. It was in front of the battery. I just need to get a spark to get started. and there is two ballast resisters
bobsundance is offline
post #2 of 2 (permalink) Old 06-17-2010, 06:44 AM
ollo's Avatar
Date registered: May 2009
Vehicle: S430 93K; E420 243K; 240D 242K
Quoted: 65 Post(s)
Check the points & make sure they are clean & opening, wouldn't hurt to put in a new set. The early transistorized ignition conversions used the existing points for a switch & over time the plastic part that rides on the cam lobe could wear away so the points no longer opened, thus giving no spark. I experienced this once on a Mallory system.
You could also try getting a whole stock system off a similar model Benz from a wrecking yard if you can find one. Don
ollo is offline
    Spark plug, spark plug wires nsupra W210 E-Class 21 09-06-2009 07:35 PM
    Spark Plugs & Spark Plug Wire Reccomendations danger450 R170 SLK-Class 2 02-19-2009 06:02 PM
    No spark deep3175 General Mercedes-Benz 0 01-17-2009 11:37 AM
    What Spark Plugs? Spark Plug gap? Spark plug used? hilarushi W210 E-Class 4 03-29-2007 11:42 PM
    No spark ?? Need help !! benzw00d W201 190-Class 0 05-16-2005 07:27 AM
