higher back - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-15-2010, 01:58 AM Thread Starter
Date registered: Dec 2009
Vehicle: 1976 300D
Quoted: 2 Post(s)
Send a message via Yahoo to amarbenj
higher back
i have my 300D 1976 benz. i have lower back part. especially when fully loaded. how can i improve the balance without touching on the shocks and springs?
amarbenj is offline
post #2 of 3 (permalink) Old 06-15-2010, 06:19 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
I don't understand your question, please re-phrase it.
renaissance_warrior is offline
post #3 of 3 (permalink) Old 06-27-2010, 08:10 AM
Date registered: Jun 2010
Vehicle: 1967/68 Mercedes 200d
I believe that he is trying to say that the back end rides low when he has a lot of weight in car.
My answer is that you can't do anything about that unless you do something with the springs or shocks. You may want to investigate "air shocks". With air shocks, under heavy weight, you can add air to raise back of car. When weight is gone you can let air out to get to desired level.
Mikiegp is offline
    I think a Higher power is trying to tell me something. the clk man Off-Topic 13 05-26-2008 07:16 PM
    Removing plastic (back lock) on the back side - below the back door samosali W140 S-Class 5 05-18-2008 12:58 AM
    Cause of Higher than Normal Idle isuccess W140 S-Class 0 01-26-2008 01:25 PM
    need a higher output alternator markland556 W124 E,CE,D,TD Class 6 08-10-2006 10:49 PM
    what is higher in (take off and speed) E55 or M5 ?!! Guest (MBNZ) W210 E-Class 1 05-11-2002 04:07 AM
