w114 280e engine stalling - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-05-2010, 10:37 PM Thread Starter
Date registered: May 2010
Hi guys need some help. My 1972 280e is sick. A week or so ago it started to have a ruff idle. First i have to tap the accelerator otherwise she won't start. Once you first fire it up its fine(thought will stall after a little while) but once its put in drive(automatic) if i leave it sit with my foot on the brake it'll stall. Once you start driving it'll hesitate under acceleration like a stumbling toddler. The engine is an Australian spec M110 engine with D-jet system.
I don't know if its related but if i wind down one of the power window the revs drop and stall the engine.
urban is offline
post #2 of 4 (permalink) Old 06-05-2010, 10:53 PM
ollo's Avatar
Date registered: May 2009
Vehicle: S430 93K; E420 243K; 240D 242K
Quoted: 65 Post(s)
Possibly a bad ignition coil or bad primary supply wire to the coil.
ollo is offline
post #3 of 4 (permalink) Old 06-06-2010, 01:08 AM Thread Starter
Do you know what model i should be looking for? or can i just use one of these:
Coils - Supercheap Auto
thanks
urban is offline
post #4 of 4 (permalink) Old 06-06-2010, 09:52 AM
ollo's Avatar
Quoted: 65 Post(s)
Bosch original equipment is the way to go. You can go to Autohaus az & put in year & model to get the correct coil but why not try replacing the power supply wire first? much less expensive & probably still available from a dealer or Autohaus. Don
ollo is offline
    My W114 feerocknok Vintage Mercedes-Benz 3 01-10-2009 11:12 AM
    w114 lilbilly11 Vintage Mercedes-Benz 2 12-19-2007 05:54 PM
    W114 280E Fuel injection 142 TPL Vintage Mercedes-Benz 3 03-13-2006 01:20 PM
    W114 280E vs W123 280CE StreekG Vintage Mercedes-Benz 4 02-11-2006 02:55 AM
    W114 MB250 Vintage Mercedes-Benz 5 08-03-2004 01:49 AM
