78 240d - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-27-2010, 06:02 PM Thread Starter
Date registered: May 2010
Vehicle: 1978 240d
Send a message via Yahoo to mvac
78 240d
i have a 78 240d and this car wont start. When you turn the key the glow plug light wont turn off. It turns but thats it. The the fuel primer pump thing seems to have no pressure i dont think this is normal but i dont know.
mvac is offline
post #2 of 3 (permalink) Old 05-27-2010, 11:22 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
It takes about 30 seconds for the glow plug light to go off.
Govert70227 is offline
post #3 of 3 (permalink) Old 05-28-2010, 09:35 AM
KCM
Date registered: Jun 2004
Quoted: 17 Post(s)
Check 2 things:
1. Loosen the hard injector lines at the injectors. Crank the engine. Fuel should leak at the connections. If not, you have a fuel problem, either air in the system, no fuel in the tank, plugged filters, or a bad delivery pump on the side of the main injection pump.
2. Turn the key on and check for voltage at the glow plugs. This car should have the series style system, which mean the voltage will drop as it goes through each plug, until it is zero where it grounds to the block at #1. If the light does not go out or does not come on, sounds like you could have a glow plug system issue. Might want to also take off all the glow plug connector links and clean them up nice and shiny to make sure you have a good electrical contact.
KCM is offline
75 240d allenb83 General Mercedes-Benz 1 03-17-2010 10:53 AM
W123 240D, then 240D, then 300D and now 230ce theoneandonlymin General Mercedes-Benz 1 02-11-2010 04:59 PM
1977 240D Motor into a 1980 240D kilbrid3 W123 E,CE,D,CD,TD,TE Class 1 05-31-2007 01:15 PM
'81 240d punky W123 E,CE,D,CD,TD,TE Class 2 01-17-2003 07:49 AM
Looking at '83 240D, the ad is like this... jsv W123 E,CE,D,CD,TD,TE Class 1 01-15-2003 08:00 AM
