What's The Biggest Widest Wheel That Fits A W111---16", 17" Or ? - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 05-26-2010, 10:51 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
I installed 16x8 chrome flat face alloys from a 600SL on my coupe and they look very classy and closely resemble the original hub caps. Some people had thought they were original. I installed studs as they make wheel installation much easier. I found special conversion lug nuts with the "Mercedes Ball" seat and topped off the studs with closed end lug nuts to hide the end of the stud-looks just like the original lug bolt.
I got some cheap spacers and used them in combinations to determine what size spacer to have made since I wanted the tire to be placed as far out in the fender as possible without rubbing. It looks much better than the wheel way inside the fender. Then I had high quality hub-centric spacers made for the correct offset. It all works very well with only a small reduction in ride quality and vastly improved handling and road feel.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #12 of 18 (permalink) Old 05-26-2010, 11:20 AM Thread Starter
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
3.5 Tony, those sound like a good fit. Got any pics. Later.
50$84sd is offline
post #13 of 18 (permalink) Old 05-26-2010, 11:35 AM
Necrosavant's Avatar
Date registered: Aug 2007
Vehicle: 1962 220S(200d engine),1970 Cadillac Fleetwood 75,1984 500SL
205-55-16 In rear// 225-55-16 in front
111 1962 220s (200d engine)
1995 S350
1983 300TD
Necrosavant is offline
post #14 of 18 (permalink) Old 05-26-2010, 05:09 PM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Not exactly a low ride, but big wheels:
GGR is offline
post #15 of 18 (permalink) Old 05-26-2010, 05:20 PM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
LOL!
benzmizer is offline
post #16 of 18 (permalink) Old 05-26-2010, 05:35 PM Thread Starter
50$84sd's Avatar
Ok I like it. Hmmmmmm.......Later.
50$84sd is offline
post #17 of 18 (permalink) Old 05-26-2010, 09:08 PM
Quoted: 8 Post(s)
Now THAT is a "Frankenbenz"
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
3.5 Tony is offline
post #18 of 18 (permalink) Old 06-04-2010, 06:30 PM
Date registered: Mar 2009
Vehicle: 1967 W110 230, 1972 250c
More wheel questions
I want to put 15 or 16 steel wheels on my fintail. I found a set of 15 steels off of a 94 w124 300d. The tires on the rims are 195x55 15. It looks like the offset
could be et41. Will that fit? I am not sure of the width. I also found a set of 16 inch steels that are 71/2 wide with an offset of et42. Maybe? Tom at the classic center has 15 steels that are 61/2 width. He also has a set of alloys that are 7 wide and he thinks that would be a tight fit? I really like the idea of the 16inch, but not sure of the fitment with the 71/2 et 42
Bla8310
Bla8310 is offline
    55 Biggest Cities Ranked By "Smarts" Qubes Off-Topic 16 10-09-2009 03:27 PM
    Question on W111 14" wheel clearance/fit 10kpharo Vintage Mercedes-Benz 2 03-09-2009 09:52 AM
    McCain's "biggest crowd of the campaign season" Marsden Off-Topic 73 09-13-2008 02:00 AM
    Global Warming "Biggest scam in history" gerkebi Off-Topic 30 12-14-2007 03:30 AM
