Orginal "H" Antenna Removal on W109 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-19-2010, 05:14 PM Thread Starter
Esquire1914's Avatar
Date registered: Jan 2010
Vehicle: 1971 300SEL 3.5 & 1980 450sl
Has anyone had any luck removing their damaged original antenna from a 300SEL... I have unscrewed the outer/above fender portion of the antenna but cannot get the antenna to unsrew from the fender...
Please tell me I don't have to remove the fender to replace the antenna...
Esquire1914 is offline
post #2 of 2 (permalink) Old 05-20-2010, 03:44 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
There's an access plate within the fender, in the wheel well. It's easiest to get to with the wheel off and out of the way. Remove that plate and you'll have complete access to the antenna, its motor and the wiring.
If the outside retaining nut is taken off and the antenna assembly doesn't fall through, you might have a stuck assembly (using a rubber mallet and light taps, it should come loose).
Grubeguy is offline
    *Warning OJWERKS is a thief, read thread*F.S: "SL" shorty antenna OJwerks R171 SLK-Class 34 06-04-2011 02:38 PM
    Modifying GPS antenna to run "straight to" XM Radio Question. danger450 R170 SLK-Class 1 03-03-2010 02:27 PM
    The all elusive "roof antenna rubber boot and gasket" FOUND !!! unlukky C208/A208 CLK-Class 5 04-16-2009 10:17 PM
    eBay "High End 3,5" Antenna for Mercedes Benz SLK" Experiance danger450 R170 SLK-Class 7 07-21-2008 11:09 AM
