1978 280ce - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-15-2010, 06:22 AM Thread Starter
Date registered: May 2010
1978 280ce
My son found a 1978 280ce for sale for $2,500.00. It has 86,000 original miles and the pictures of the interior and body look good. Are there any particular questions we should look for? Any help is appreciated!
katkos is offline
post #2 of 2 (permalink) Old 05-17-2010, 07:00 AM
Date registered: Aug 2009
Quoted: 49 Post(s)
Rust, especially in the hood hinge pockets, battery tray area, along the rear window and in the rear floorboards.
If it has the U.S. style of heater controls (ACC or as I call it, "Aggravating Cash Consumer") then make sure it works. Check the water servo in the engine compartment for operation and any evidence of leakage.
The glass for the "C" model is PRICEY! Cracked windshields can be a deal killer. If the rubber is bad around the windscreens it needs to be replaced pronto! Figure on about $600 for parts and labor. More if there is rust under the gaskets.
Fuel injection system can be problematic. Great system unless it's been neglected. Can be VERY costly to bring back to snuff.
Cruise control amps are usually flaky but a fairly inexpensive fix.
Rubber mounts are usually dried out (engine mounts, rear suspension mounts, flex disks, etc.) and hard. Normal maintenance items affected by time so mileage don't mean squat regarding them.
Mike D is offline
    1978 280ce katkos General Mercedes-Benz 1 05-15-2010 06:29 AM
    1978 280ce katkos General Mercedes-Benz 0 05-15-2010 05:45 AM
    w123,1978,280ce. happy1 W123 E,CE,D,CD,TD,TE Class 2 06-17-2008 12:52 AM
    1978 280CE.... needs a new home Cyberbach W123 E,CE,D,CD,TD,TE Class 0 12-21-2005 08:15 PM
    FS 1978 280ce coupe Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 0 11-07-2001 06:53 PM
