1973 450SL ticking sound - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-14-2010, 06:38 PM Thread Starter
Vehicle: 1973 450 SL
I have a fantastic 1973 450 SL,, I put the car away each winter.
It has 55 k original miles
I have 2500 miles on the oil and filter (changed 2007 summer) its clean
I started it and now it ticks rick side manifold area,
I drove it 60 miles same tick and then another 30 still ticking
my plan was to change the oil, its very clean but change it,,,
Im woried about it,, the mechanic says drive it and it might stop ticking,,,,
I dont know what to do...
its a stunning car all original,,Im affraid of any damage,,, some one HELP!!!
rochesterbenz is offline
post #2 of 4 (permalink) Old 05-14-2010, 08:32 PM
Vehicle: 2000 ML320, 2005C240 4matic wagon, 1962 220SEb, 2002 CLK55 Cabrio, 2014 C300 4matic, 2000 CLK55
Quoted: 2 Post(s)
I would change the oil more frequently as moisture accumulated during storage can result in the formation of sludge. The ticking noise may be due to oil sludge in the lubricating tubes located over the solid type cam shafts. The tubes are connected to the top of the cam bearing housings and spray oil onto the cam lobes. It is easiest to remove the tubes and clean using a solvent or replace them with new ones.
yaki b is offline
post #3 of 4 (permalink) Old 05-14-2010, 09:05 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 16 Post(s)
Or it may just be a leaking spark plug boot. Find somewhere dark and run the engine.
Nutz 4 Benz is offline
post #4 of 4 (permalink) Old 05-16-2010, 07:15 AM
72benzyacht's Avatar
Date registered: Apr 2010
Vehicle: Master Technician Mercedes benz 11 years
Oil tubes maybe. And easy to change. (cheap for the kit also) Dont forget that it may be as simple as an exhaust leak at the manifold! Can easily be mistaken for an engine tick. Gaskets are cheap. Good luck. (use a 2 foot long piece of 3/8 fuel hose or vacuum hose and with car running hold one end you your ear and follow with the other end around your manifold if you hear the noise very clearly youve found you noise!!!
2011 ML350
2000 C230 sport (modded)
1972 SEL 280 4.5 (sold)
2010 E350 (sold)
2009 E550 (sold)
2007 E350 (sold)
72benzyacht is offline
    1973 450SL- No Start tombstone R/C107 SL/SLC Class 20 06-27-2015 09:26 AM
    1973 450SL lfedje R/C107 SL/SLC Class 37 08-15-2011 08:43 PM
    1973 450SL windows Menehune R/C107 SL/SLC Class 4 02-11-2011 04:48 PM
    1973 450SL windows Menehune Vintage Mercedes-Benz 0 02-03-2010 09:50 AM
    Should I keep this 1973 450SL? DeidreB R/C107 SL/SLC Class 2 06-13-2004 10:10 AM
