71 280 sel timing problem? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-11-2010, 08:20 PM Thread Starter
Date registered: May 2010
Hi, I have a 1971 280 sel in perfect condition, just purchased it and had it running , I went and changed the wires ,plugs and points to give it a tune up and now it just turns over ,has spark but won't fire.is the firing order on the block #1 2 3 4 5 6 and on the distributor cap is it clockwise or counter clockwise?This benz sat in a heated garage for 30 + years and is excellent condition so i would like to get it running and enjoy the summer with it.It is a 6cyl 2.8. If anyone can help that would be great Thanks.
71280sel is offline
post #2 of 4 (permalink) Old 05-11-2010, 09:19 PM
Date registered: Jan 2009
Vehicle: 1970 280 sel, 1979 300sd, 1988 300sel
Quoted: 10 Post(s)
Check to see if you mixed up the wires. Been there.
xaliscomex is offline
post #3 of 4 (permalink) Old 05-12-2010, 02:10 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
I would suspect that your points closed up on you. Re-check and re-adjust.
renaissance_warrior is offline
post #4 of 4 (permalink) Old 05-12-2010, 04:08 PM
cadurning's Avatar
Date registered: Dec 2009
Vehicle: '72 280SE barn find
I for got which way the rotor turns, just crank the engine and watch the direction that it turns. The firing order should be on the valve cover 1, 5, 3, 6, 2, 4. The front cylinder is #1.
If it's not broke it dosen't have enough features.
cadurning is offline
    74' 280 Timing 74benzo Vintage Mercedes-Benz 2 05-18-2010 08:15 PM
    79 280 CE- Timing cparent W123 E,CE,D,CD,TD,TE Class 6 05-08-2010 01:56 PM
    When should the timing chain be replaced for a 1985 280 SE? bluetec7 W126 S,SE,SEC,SEL,SD,SDL Class 7 01-28-2009 01:38 PM
    Starting Problem on 280 SEL dilanja W126 S,SE,SEC,SEL,SD,SDL Class 7 01-13-2006 09:24 PM
    72 280 sel problem heylacy W116 S, SE, SEL, SD Class 7 11-29-2005 06:23 PM
