1974 450sl - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-11-2010, 05:56 PM Thread Starter
Date registered: Apr 2010
1974 450sl
I just installed rebuilt fuel injectors, rotor, distributor cap, spark plugs with wires and the engine still has a major miss fire. What should I check out next?
ironhansen is offline
post #2 of 4 (permalink) Old 05-11-2010, 08:53 PM
Date registered: Jan 2008
Possibilities
Have you checked the spark plug wires to make sure you have the correct firing order. Also does your distributor have the extra points in the lower part of your distributor. If there are wires going to your distributor about the 8 oclcock position when you are standing in the front of the car looking down and the rear of the distriutor is 12 oclock... Jim
jimh16671836 is offline
post #3 of 4 (permalink) Old 05-11-2010, 10:34 PM Thread Starter
Thanks Jim. I will check the distributor out for the extra points...........Mike
post #4 of 4 (permalink) Old 05-12-2010, 12:19 PM
Date registered: Dec 2009
Vehicle: 1972 350 SL
Timing could also cause a miss and sometimes a backfire under hard throttle.
robbin is offline
1974 450SL Guest (MBNZ) R/C107 SL/SLC Class 5 06-17-2011 06:57 AM
1974 450sl on ebay alexnatt R/C107 SL/SLC Class 0 03-23-2009 10:36 AM
Fs: 1974 450sl TheJackal3006 For Sale/Wanted/Trade/Giveaway 0 05-31-2006 05:39 PM
Headrests - 1974 450SL Guest (MBNZ) R/C107 SL/SLC Class 1 05-23-2002 10:12 AM
1974 450SL Guest (MBNZ) General Mercedes-Benz 1 07-17-2001 08:08 AM
