What is this hose and why does it exist? (zenith dual carb w/ pics) - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-09-2010, 02:14 PM Thread Starter
Date registered: Apr 2010
On a zenith dual carb system I found this hose underneath my air filter housing just kinda flopping around.
It should be connected to this part of the filter.
Connects to the hose here.
Leads down into a connection between the two carbs.
It looks like it should be something to feed the fumes back into the top of the carbs. Am I right? What happens when it's not connected?
*starts tracking down a clamp to hold it*
EricDr is offline
post #2 of 2 (permalink) Old 05-09-2010, 09:04 PM
Vehicle: 2005 C350, 2002 ML270CDI, 1969 230S, previously 2002 A160, 1985 380SEC ivory, 1983 380SEC grey
Hi Eric,
my 1968 230S has a similar hose, and I believe it to be the crank case breather.
As engines suffer wear and tear, the piston rings let small amounts of burnt gas into the sump, which pressurises it with oil fumes. They have to go somewhere other than pollute the atmosphere, so there is usually a hose or a pipe to redirect the fumes into the carburettor intake, 'recycling' them.
It would be best to restore the connection...
Audiophile_AU is offline
    Zenith Carb running too rich Waiakoafarms Vintage Mercedes-Benz 1 05-05-2010 08:51 PM
    404 Zenith Carb Alternative Oldmog Unimog 3 11-05-2009 06:20 PM
    '63 280SB Non Zenith Carb Kit Autowerks Vintage Mercedes-Benz 2 11-22-2007 11:03 AM
    W111 Zenith Carb Rebuild Kits Richard 220Sb Vintage Mercedes-Benz 2 07-24-2007 04:54 PM
    Zenith parts carb ggenovez Vintage Mercedes-Benz 2 09-08-2005 05:04 PM
