Advice on DIY/1973 280 SE - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-07-2010, 06:51 AM Thread Starter
Date registered: Jun 2009
Vehicle: 1979 450SL; 1973 280SE 4.5; 1986 420 SEL(SOLD)
I will be receiving my new to me 1973 280SE 4.5 next week. The PPI identified some items needing attention. I have little to no wrenching experience, but think I want to try some things myself. Here's the list - looking for advice on which ones I should think about doing myself and degree of difficulty.
- left lower and upper heater levers need replacing
- rubber door seals need replacing
- missing bushing in transmission linkage
- trans cooler hoses old
- missing rubber grommet on transmission cooling line
- turn signal flashers won't hold and flash fast
- one window inop, other three are "jerky"
- front dome light assembly bad
- front flex disc cracking
Thanks for your input.
dickz is offline
post #2 of 3 (permalink) Old 05-11-2010, 10:52 AM
nhmercracer's Avatar
Date registered: Aug 2006
Vehicle: 99 C280
You should be able to do the flex disk easily. I would do this first, as if it fails, it will damage the transmission. The flashers most likely just needs a new relay module.
Wish I was there to help.
nhmercracer is offline
post #3 of 3 (permalink) Old 05-11-2010, 11:39 AM
ulflei's Avatar
Date registered: Aug 2005
Vehicle: 85 300SL Euro,97 SL320,95 S420,07 S550
Quoted: 2 Post(s)
I would recommend to find an Indy in your area who is experienced with older cars and let you watch.
You will make more damage and spend more time when you try to do it yourself with no mechanical background ,no proper tools and location
ulflei is offline
    FS-1973 MB 280 SE 4.5 rberd For Sale/Wanted/Trade/Giveaway 2 03-28-2010 08:33 PM
    1973 280 SE 4.5 Vintage Mercedes-Benz 1 12-05-2008 04:03 PM
    1973 280 kardar Vintage Mercedes-Benz 5 11-06-2006 07:24 AM
    1973 280 Se 4.5 gtwillis Vintage Mercedes-Benz 7 09-02-2006 03:43 AM
    Advice on buying 1973 280 4-door Gazolba Vintage Mercedes-Benz 3 09-01-2006 08:55 PM
