horn won´t stop - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 05-19-2010, 11:45 AM
Date registered: Apr 2010
The liquid tape wore through on mine after about a week is why I'm curious
EricDr is offline
post #12 of 25 (permalink) Old 05-19-2010, 12:37 PM Thread Starter
Date registered: May 2009
Vehicle: 1970 W111 280 SE Coupe
Then, I guess, we will need to find a more permanent solution to keep the rod in the column shifter from poking out and hiting the copper circles that activate the horn.
Has anybody out there had a similar problem and knows how to fix it?
Perhaps it is more difficult than we think and it should be better looked at by a MB mechanic.
At least we know where the problem is...
FMPH is offline
post #13 of 25 (permalink) Old 05-22-2010, 07:58 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Wow... can't believe how recent these posts are I was just about to start looking into the honking when turning too... I've had the wiper/horn fuse out in my '64 220s for about a year now.
Maybe a hard plastic cap over the shifter rod would provide better protection?
I started looking into it last year, but I couldn't get the steering wheel nut off and kinda just gave up...
I'll have to use a bigger wrench this time and see if that shifter rod is my problem too...
theres got to be a way to either get the rod back where it belongs or cover it with something that will last longer than a week.
tgikal is offline
post #14 of 25 (permalink) Old 05-22-2010, 11:14 AM
I barely know anything about the steering wheel assembly in this car myself but it's one of two things.
1) The shifter rod is spring loaded and whatever is supposed to retain that spring has worn out. This would require a fairly large teardown to get two as there's a nice solid steel cover preventing you from getting to anything.
or
2) The steering shaft is supposedly a telescoping rod and over time this has shifted downwards and needs to be readjusted so it pokes up higher and the steering wheel itself doesnt push down quite as far to meet it.
To get that nut off I took off the steering rim (the part that has the actual horn ring on it) so I could get into the base easier and then used a "Hand Impact Driver" which you smack with a hammer while turning to loosen the nut. Once I did that for a while and let some wd-40 soak in I was finally able to get the nut off with a normal socket wrench. (still took quite a bit of force to get off even after that)
edit* for the time being tho I've just strung a couple of wires off the turn singal switch and fed it to a cheap button installed in the center console .
Gotta pass state inspection and a button is good enough as long as the horn "works".
EricDr is offline
post #15 of 25 (permalink) Old 05-23-2010, 03:43 PM Thread Starter
Hi EricDr,
I was able to take the metal plate and look behind. It is not difficult. Just remove the safety ring on the steering column (the small one), the safety ring on the shifter rod and the four bolts. Be careful when pulling it out not to damage the horn cables running from the copper prongs to the turn signal switch. These need to be unhook from the switch.
In my case behind this plate, on the shifting rod, were the remains of some sort of washer, which had worn out. This may be why the rod is poking out to much and touching the copper circles.
So we need to get that washer. Unless you can get the real one from MB, perhaps have one made of plastic or teflon???
I will take some pictures once I put it back together.
FMPH is offline
post #16 of 25 (permalink) Old 05-23-2010, 06:30 PM
Thumbs up
I'll probably end up using an impact wrench on it, when I get to it, I just never seem to have the car, air compressor, and impact wrench in the same place at the same time...
I'll definitely be waiting to see these pics of this shifter assembly and what kinda washer we're looking at. (probably nylon?)
tgikal is offline
post #17 of 25 (permalink) Old 05-24-2010, 08:03 AM Thread Starter
I forgot to mention that to remove this plate the turn signal/wiper/high beam switch also needs to be removed, as HBguy described earlier in this thread.
FMPH is offline
post #18 of 25 (permalink) Old 05-24-2010, 11:36 AM
I just got back from the shop. I found a guy who's about 70 years old and has been working on Mercedes since 1957
He was tuning my idle and while we were waiting for it to cool down I brought up the horn issue.
He said he'd seen this happen millions of times.
The fix for this apparently is to get replacement plastic bushings for that bit of the shifter that sticks up. They're made of soft plastic and just deteriorate over time. One goes underneath the E-Clip on the shifter and another just sits right on top (with basically nothing to hold it there, just sits on top).
So that's it. That's the fix. Mine must have been lost ages ago when someone else did work on it.
EricDr is offline
post #19 of 25 (permalink) Old 05-24-2010, 01:49 PM
Date registered: Feb 2010
That makes sense...there's plenty of space for another bushing in there and I had quite a bit of plastic 'shavings' in the area when I first took it apart. thanks for the info.
Former MB: "Miss Juliana" - 1972 280SEL 4.5
Current MB: 2013 C250
HBguy is offline
post #20 of 25 (permalink) Old 05-24-2010, 02:52 PM
I don't suppose you got a part # for that bushing? I can't get the ewa-net program to connect to server.
HBguy is offline
    S500 Wipers won;t stop on OFF Position. HELP!!!! benzoboy W220 S-Class 8 04-25-2011 04:38 PM
    Horn stop working, where is the fuse for the horn njstreeter W203 C-Class 1 09-09-2008 09:53 AM
    Sprinter stop/stop system Fulcrum525 W901-905 Sprinter 0 02-19-2006 02:52 PM
    Pressing STOP lever does not stop engine, Help! IceBlue_1980_300TD W123 E,CE,D,CD,TD,TE Class 5 08-12-2004 04:41 PM
    Is there a "horn mod"? My horn seems a bit soft and more of a beep than a HONK. Thanks. J-bird W163 M-Class 36 12-02-2003 08:40 PM
