OM617 Cranking Slow, Not Firing - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-01-2010, 10:59 PM Thread Starter
Date registered: May 2010
I have a '76 300D, was running until fall, lost trans fluid & parked for winter. Just now replaced radiator & added fluid, 65 degree weather, attempted to start, but cranking very slow. Installed new starter, freshened contacts on all grounds, checked neutral switch, removed all glow-plugs to release compression, even jumped direct to starter with fresh 1,650 CCA truck battery, still cranking slow regardless of all the above... Can this be result of transmission/torque converter locked up?
Would separating trans from engine free drag from engine?
If I find this works to start the engine, any suggestions on the trans/converter?
dieselvanman is offline
    Engine isn't cranking up? HELP!! manicdemise R170 SLK-Class 21 06-14-2013 12:00 PM
    i need help (cranking it up) javielito W163 M-Class 8 10-17-2009 06:38 PM
    Slow Cranking! superstar W203 C32 AMG, C55 AMG 5 05-27-2009 11:48 AM
    again cranking-- student123 W202 C-Class 7 07-22-2007 10:14 PM
    Slow and fast cranking graftdesign W126 S,SE,SEC,SEL,SD,SDL Class 3 11-17-2006 07:03 PM
