Sunroof jammed '72 300 SEL - help! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-30-2010, 06:05 PM Thread Starter
Date registered: Apr 2010
I bought a '72 300 SEL and the sunroof is stuck in the almost closed position. That is, the back edge has not lifted up into position. The previous owner removed the headliner from the sunroof. The manual override in the trunk only turns a very small amount in either direction and someone has tried so hard to turn it that the bracket holding the gear housing is bent a little bit. The motor has been detached and the gear box is fine.
How should I proceed to find the fix for this problem?
benzford is offline
post #2 of 2 (permalink) Old 05-01-2010, 10:29 AM Thread Starter
I think I have found the problem. The cable is damaged at the point where the sunroof is almost totally closed. I can now open the sunroof. But, my factory manual does not have any info on changing the cable, removing the sunroof, etc. Can anyone direct me to an information source? Thanks
benzford is offline
    Sunroof jammed jokki W126 S,SE,SEC,SEL,SD,SDL Class 22 08-26-2016 11:12 AM
    Igition Coil Module from my 89 560 SEL to a 300 SEL BigBoiH W126 S,SE,SEC,SEL,SD,SDL Class 1 05-08-2009 11:34 PM
    About SEC,SE,SEL Sunroof mechanisms? Jukka L. W126 S,SE,SEC,SEL,SD,SDL Class 2 08-31-2008 07:27 AM
    280 SEL SUNROOF verdejor Vintage Mercedes-Benz 3 06-04-2008 10:49 PM
    300 SE sunroof problem RogerJones W126 S,SE,SEC,SEL,SD,SDL Class 9 05-03-2008 03:18 PM
