280SE 3.5 71 coupe overheating - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-27-2010, 06:35 PM Thread Starter
Date registered: Apr 2010
I have a 71 280SE 3.5 coupe. It seems to always had a problem in warmer weather with getting hot while driving either in traffic or on the highway. Last weekend the weather was around 75-80, I drove 50 miles on the highway and still my temp gauge was hovering around 180-200?? In stop and go traffic it will red line.
Could it be a stuck thermostat? Could the radiator need to be recored? Could the timing be off causing the temp to rise.
Another problem is than when I drive on a warm day and the car does get hot. When I try and restart the car say after 20-30 minutes of sitting, it has a very hard time starting. It just sputters, and acts like it's not getting gas. I have to pump the accelerator continuously to get the car started.
Any suggestions would be greatly appreciated.
Thanks,
DB
dbglobal is offline
post #2 of 2 (permalink) Old 04-28-2010, 08:51 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
I would suggest replacing your fan clutch, thermostat and radiator. Timing will never cause heat like that. It also appears that your temp sensor is bad as well, the one that goes to the computer. All simple fixes.
renaissance_warrior is offline
    1968 280SE Coupe Corkscrew Vintage Mercedes-Benz 180 05-11-2016 02:23 PM
    OVERHEATING S500 COUPE XROBK818X W140 S-Class 3 05-07-2009 12:22 AM
    interested in 280SE 3.5 coupe mercman1104 Vintage Mercedes-Benz 2 07-24-2008 05:15 PM
    1971 280SE 3.5 Coupe Minkoff Vintage Mercedes-Benz 2 01-31-2006 01:27 PM
    on a quest to find a 280se coupe or 250se coupe..w111 bodystyle ventura250s Vintage Mercedes-Benz 3 06-01-2005 08:33 PM
