Replacing W111 Sedan Back Window Rubber -- How Tuff ? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-24-2010, 09:37 AM Thread Starter
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
Well, my back window has been leaking for years now and water has done some minor damage, so I think it's time to do something about it. I've seen the rubber for pretty cheap nowadays so it's time to replace. Has anyone done this and what's involved. I know the removal is probably the simple part and I've done back windows before (not a Benz though) but what about the reinstalling of the chrome back there, or do I need to pay $200. at a shop. thanks. Later.
50$84sd is offline
post #2 of 4 (permalink) Old 04-24-2010, 10:29 AM
Pulling the cord.
Be really careful as the 40yr old glass is more fragile than new.
I would find an old pro to go slow and have prior experience, trim parts may need new clips if existing ones are rusty. remove window by cutting rubber with razor knife. fix all rust spots. headliner replacement at this time is recommended.
Brian O
bostosh is offline
post #3 of 4 (permalink) Old 04-25-2010, 05:43 PM
CRJ9Driver's Avatar
Date registered: Nov 2009
Vehicle: 1956 Buick Century Coupe, 1937 Pontiac Business Coupe
Even though removing the chrome trim strips attached to the rubber seems easy it is really hard, because they are aluminum and the bend very easy as you pull them out... You have to be careful when you remove them, take your time, go really slow and try not to "pull" them out and here is why: once you install the rubber seal on the glass then you have to install the chrome trim before you install the glass into place using the cord or weed wacker string. If the strips are bend they will keep on popping as you try to pull the glass in from inside... Everytime they pop you will have to stop, remove the glass, put the strips back in, straighten them and try again ang again and again... All day and close to all night trying to figure out what went wrong... they were coming out straight, but actually they were not because it seemed easy and you did not know how fragile they were... Well now you know!
The rubber is cheap it is the labor that is expensive and will drive the cost up. Once you do the rear do the front one too... Be careful removing the glue the factory used to seal the rubber to the glass and the rubber to the chassis... Hard as rock. You will damage the headliner edges as it is tucked underneath the seal... Unless you planning on replacing the headliner too... then you will need a sealer to seal the leaks between the rubber and the chassis around the lower corners, as gravity pulls water toward the lowest corners... The place it leaks now... You are up for a treat my friend! Good luck to you.
CRJ9Driver is offline
post #4 of 4 (permalink) Old 09-22-2010, 01:08 AM
Date registered: Apr 2009
Vehicle: 1962 220Sb, 1972 280C, 1987 300SDL, 1985 Porsche 911 Carrera
I paid $125 to have the rear window gasket changed by a professional. It took that guy three attempts before the gasket seated correctly. It was money well spent... After watching him do the job, I would rather pay than do it myself.
JeffreynHouston is offline
    engine conversion for a w111 sedan ifzal_uk Vintage Mercedes-Benz 7 12-26-2010 04:26 AM
    W111 sedan dash vs coupe CRJ9Driver Vintage Mercedes-Benz 3 11-24-2009 02:47 AM
    WANTED: Power steering for W111 '61 sedan bens280e For Sale/Wanted/Trade/Giveaway 0 06-22-2009 05:22 AM
    Help W111 and W112 rubber jim dorociak Vintage Mercedes-Benz 10 10-19-2007 06:37 PM
    W111 Sedan Dash Replacement/Repair DanB Vintage Mercedes-Benz 0 06-16-2005 08:28 PM
