stiffening W111 Chassis - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-24-2010, 06:08 AM Thread Starter
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Hi all,
at one point or another all mechanical elements of my W111 Coupe will come off it so that I replace them with the ones I am preparing to go with my 5.0 engine. I may take this occasion to inspect welds and add some where needed to stiffen the chassis. I know this is a method used by people who race their cars.
What are the areas I should inspect for fatigue? Where should I add weldings to stiffen the car?
Thanks in advance!
GGR is offline
post #2 of 3 (permalink) Old 04-24-2010, 11:36 AM
Steering box area, thru rail fittings can develop cracks,
Wire brush clean around the three thru tubes and visually check.
The W111 cabriolet came with under body stiffener,
these plates are the factory answer, check the EPC
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 04-24-2010, 12:35 PM Thread Starter
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Will do, though that steering box area is more prone to cracks on 6.3s due to the weight of the engine.
These metal plates under the convertibles must be very heavy. I'm wondering if making them out of slightly thicker aluminum would be a good idea?
GGR is offline
    Modifying chassis rail on a W111 Coupe to fit a 5.0 M117 GGR Vintage Mercedes-Benz 11 04-12-2010 12:43 PM
    Stiffening Chassis on W210? RaffiB W210 E50 AMG, E55 AMG 0 01-29-2009 11:39 PM
    W111 mechanical fuel injection cold start 1963 W111 220 SEB MercedesOtto Vintage Mercedes-Benz 1 07-29-2007 04:29 PM
    ML ..Is the actual chassis stamped with the chassis number alphonsohall W163 M-Class 2 02-12-2007 07:38 AM
    Stiffening Up the Brake pedal Tubs300E W124 E,CE,D,TD Class 13 12-18-2003 03:37 PM
