1965 190c Heckflosse Barn Find - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-22-2010, 11:37 PM Thread Starter
Date registered: Apr 2010
Hi there, I am new here and have just bought a 1965 Heckflosse and thought I would share it with you guys. It has a story with it (as i'm sure they all do) but this is a real "barn find" in a certain respect. I got this car from Portugal (on portuguese plates and right hand drive) The last owner bought it 23 years ago with the story of it being a car that had escaped the war in mozambique (I have the mozambique orig reg doc) hence being right hand drive. He then stored it in his fathers garage where it has been ever since!!! His father sold up and the car had to be moved outdoors in december last year and probably wont have lasted to long with portuguese heat etc. My intentions are to try and MOT,register and then do a full restoration on it. I have noticed that the hub caps are different to most of the pics I have seen and wondered if anyone could shed some light on there origination or indeed if they are correct spec and just an upgrade or a different hub cap for a different countries spec etc ??? All advice on parts and specialist on this type of car would be most welcomed as I am sure I will need some help with certain things on this car. Any ways enough waffling let me know what you think.
P.S Does anyone know where the chassis number is on these cars?!?
All the best and happy mercing
Stephane Wright (UK)
ID:	304154   Click image for larger version
ID:	304155   Click image for larger version
ID:	304156   Click image for larger version
ID:	304157   Click image for larger version
Dr. Robert likes this.
65heckflosse is offline
post #2 of 3 (permalink) Old 04-23-2010, 01:48 AM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 32 Post(s)
Good luck with your find! I have never seen wheels like that though!
Chassis number should be stamped into the top of the RH chassis rail, down toward the headlight. Perhaps a handspan or two back from the headlight.
Cheers, Drew
EDIT - see the picture below. When I say right hand side, this is relative to a person sitting in a seat. You can see that the number is quite a way back from the headlight - just on the front side of the front subframe mount.
drew56cus is offline
post #3 of 3 (permalink) Old 04-24-2010, 10:49 PM Thread Starter
Nice one Drew...... Thats exactly where it was!!! It was so caked in grease it looked like a flush chassis rail!!!! All the best and good luck with your Merc.
    Need a Title For a Barn Find robbin Vintage Mercedes-Benz 6 01-23-2010 11:14 AM
    '78 280SLC barn find Euro280SLC Vintage Mercedes-Benz 10 07-12-2009 07:41 PM
    Barn Find of the Decade DP Off-Topic 4 01-02-2009 05:19 PM
    A Major Barn Find... dave420 W126 S,SE,SEC,SEL,SD,SDL Class 9 07-23-2007 08:04 PM
    Barn Find Ears R/C107 SL/SLC Class 12 04-02-2007 04:13 AM
