1970 distributor help - the pin snapped! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-22-2010, 04:18 PM Thread Starter
Date registered: Dec 2009
Hi all !
I have recently acquired a 1970 280 sel. 6cylinder with dual zenith carbs- while changing the points , the brass pin snapped( had to have been cracked to start) any suggestions on what to do to repair the pin? Bosch dist #ujur6br47t-
From what I have been able to read , this is not the correct engine set up and it appears to be a 1969 engine from a 280S
any thoughts? would prefer to keep the points setup rather than electronic conversion
jimirover is offline
post #2 of 2 (permalink) Old 04-23-2010, 04:26 PM
Is the broken pin the pivot of the points?
Put a Crane system in
Or get another distributor
There is a bosch distributor rebuild expert out there somewhere
Rebuilt Bosch 383 / VJ4BR25 / 010 / VJ4BR8 / 019 / VJR4BR18 / 022 / VJU4BR8 / "Big Cap" 40hp Distributors
Brian O
bostosh is offline
    9-Pin or 10-Pin Fuel Pump Relay w/ Kickdown woulfe27 W201 190-Class 3 10-22-2013 11:38 AM
    Headlight install question - 4 pin and 3 pin TO 5 pin and 2 pin eurodriver W202 C-Class 3 12-20-2010 07:15 PM
    1970 406 Cardan info/ king pin breakdown ALASKAT Unimog 13 10-26-2009 03:52 AM
    HELP ! 38 PIN diagnostic plug pin numbering mrmuzic W124 E,CE,D,TD Class 4 09-04-2009 07:04 AM
    Single pin or 2 pin brake pad? southbusiness W210 E-Class 3 05-11-2009 04:21 PM
