ITS GETTING BAGGED!! Any helpfull info? - Mercedes-Benz Forum
post #1 of 41 (permalink) Old 04-22-2010, 10:49 AM Thread Starter
72benzyacht's Avatar
Date registered: Apr 2010
Vehicle: Master Technician Mercedes benz 11 years
Post ITS GETTING BAGGED!! Any helpfull info?
Whats up guys. I'm gonna bag the 72. I'm real excited. I'm going full aftermarket with a set from bagit.com. Any one have any HELPFULL info for me with situations I might run into.,. Thanks guys the last 2 pics were my inspiration.
ID:	303996   Click image for larger version
ID:	303997   Click image for larger version
ID:	303998   Click image for larger version
2011 ML350
2000 C230 sport (modded)
1972 SEL 280 4.5 (sold)
2010 E350 (sold)
2009 E550 (sold)
2007 E350 (sold)
72benzyacht is offline
post #2 of 41 (permalink) Old 04-22-2010, 04:02 PM
I've got two of those in that exact color, 4.5 and a 6 cyl.
Brian O
bostosh is offline
post #3 of 41 (permalink) Old 04-22-2010, 06:56 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
If you notice the pics you like, the rear wheels are cambered dramatically making the car impractical/unsafe to drive. I suppose you could show it off sitting still, but you'll have to raise it to near normal height to get the rear wheels straight so you don't chew up the rear tires.
That's the downside of swing axles as opposed to IRS or a live axle.
Good luck.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #4 of 41 (permalink) Old 04-22-2010, 09:27 PM Thread Starter
Thats my only concern. but have a solution. I can put an adjustable either air bag bellow there or a pneumatic adjustable strut which is what came on the 300 to adjust the camber when the vehicle is lowered. Just have to design something that would work. I wouldent need any sensors basiclly just eyeball it and GO.
2011 ML350
2010 E350 (sold)
2009 E550 (sold)
2007 E350 (sold)
post #5 of 41 (permalink) Old 04-22-2010, 10:57 PM
Date registered: Sep 2009
Vehicle: 72 280 se 4.5 and a bunch of other german cars
im all for this. keep track of what kit you bought and anything you ran into. I want to get rid of the 4x4 look myself, but was leaning toward shock/spring setup. However, i wouldnt rule out the air bags either.
Easy to get around the rear camber issue. of course you wont be able to get rid of all of it. however, you can size the bags right to where full height is acceptable to drive on while still being lower than stock.
Personally, if i were to bag the car and keep stock 14 inch tires-- chewing through a pair of tires a summer would be least of my concerns. Imo, the cost of two tires is relatively cheap compared to the joy of driving the car.
The camber itself doesn't scare me either. lets be realistic, if you are running a car lowered like that, you are going low and slow and not exactly looking to shred corners. Hell, i see worse camber on fwd hondas that are improperly lowered.
mtkst19 is offline
post #6 of 41 (permalink) Old 04-23-2010, 01:46 AM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
72benzyacht, can you please explain to me how you can level up the swing arms to fix the camber whilst keeping the car low? Basic geometry tells me that this is impossible with the top of the diff being a fixed position.
I think you should get under the car and have a look at what is under there...
drew56cus is offline
post #7 of 41 (permalink) Old 04-25-2010, 07:02 AM
Jackasic's Avatar
Date registered: Jul 2005
Vehicle: 72 280SEL 4.5(airbagged), race cars:88 560 SEL, 74 SLC, 67 200, daily: 99 C43, 06 E55 wagon
don't worry about the rear wheels, that isn't enough to affect the handling. the crappy stock tires are a larger limiting factor.
For bags, there are couple of good places. With all things, if you spend a little more you will be better off. For example get Goodyears and not Slams, I would also go with 4 valves and tie it together. check out RideTech.com - Air Suspension Specialist for better info. I am swapping over stuff from my 300 (track car) to my 280.
Performance parts for w126, r/c107, w201, m117, m119, m102, m104 and few other things.
Reproduction 17" Penta wheels coming soon.
Feind Motorsports
Jackasic is offline
post #8 of 41 (permalink) Old 04-26-2010, 01:36 PM
Date registered: Apr 2009
i have looked into bags for my finny... And as for the camber situation, to do it all properly you most likely should find a new rear end with independent suspensions, or your camber will chew your tires, starve the end far end of the whole rear of oil, and you will go through wheels seals because they need o be lubricated!
eclipse_22 is offline
post #9 of 41 (permalink) Old 04-26-2010, 10:50 PM
ChopTop250SE's Avatar
Vehicle: 1967 250SE RHD, 1969 300SE L, 1989 560SEC with AMG upgrades, 1998 s600 coupe
Send a message via MSN to ChopTop250SE
Nice w108 man.....that is a real clean one.... I do not see why the camber would be any danger ....You cannot drive it slam anyways, so do not even worry....the only time where you can drive the car slammed is on a straight flat road, and I see no danger there..... If you keep it at a low stance while driving. not slammed, the camber will hurt nothing except tires.... No danger, if anything, you will have better cornering....
Get hold of Air Ride technologies....They have air struts (shocks)....instead of conventional big air bags you can use those...They do not take a lot of room, easier to mount. I doubt that you are looking to hop this car up and down..... So you can use electronic adjuster with diff set-ups....With a push of a button the car will raise or lower to the pre-set height.....
ChopTop250SE is offline
post #10 of 41 (permalink) Old 04-26-2010, 10:55 PM
FOrgot to support Jackasic He's right....you cannot get rid of the camber in any way....Unless you replace your whole rear end.....
Also: Yes, make sure you go with 4 valves...4 independent feeds....
A decent custom shop should be able to install the whole deal for around $1500 or less.....Compressor, air tank, 4 bags, valves, lines, conrtoller + labor.....
    bagged w124?? boostAbear W124 E,CE,D,TD Class 16 02-13-2010 10:13 AM
    Bagged ML? frets.217 W163 M-Class 4 04-02-2009 08:53 PM
    helpfull uncle nitro-express General Mercedes-Benz 1 03-30-2009 01:41 PM
    air bagged suspension... eykeykeyk W220 S-Class 1 03-06-2008 07:57 PM
    Need some helpfull advice denisj22 G-Class 5 10-23-2007 10:44 PM
