1973 280SEL (116 025) heater controls / water entry - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-19-2010, 11:32 AM Thread Starter
Date registered: Apr 2010
Vehicle: 1973 Mercedes-Benz 280SEL (German domestic production)
Hey all ...
I posted some general info about my car as an intro here.
I seem to have a jammed defrost duct door mechanism that has me a little baffled. The 10mm nuts on either end of the heater controls pivot were loose - in retrospect, probably done intentionally to protect the mechanism from being forced and broken. It may be that some foreign object(s) have found their way into the defrost duct outlets from above - I didn't lose anything down the outlets but, as mentioned, this could be a long outstanding issue initiated by the previous owner(s).
I have no owner's manual or service manual literature to guide me so have no concete ideas about what the control symbols mean or a procedure for setup / adjustment of the heater controls. See att. JPG photo of my heater controls.
It seems like there is a control rod to each defrost duct door on either side with a heater duct door (?) control rod forming part of the linkage on the R side. With said linkage still intact, when manipulating the heater duct door (?) control rod on the R side, the little bit of movement possible seems to be stopped by the R defrost duct door control rod and whatever is jamming the door.
The defrost duct doors were likely never meant to be independently operable, so, I have wondered to myself if, instead of foreign object entry as the issue, perhaps one or both doors have rotated past its'/their normal operating range and is/are consequently bound up / over-center somehow... or ... is there some control sequencing / procedure to setup / adjust these controls that has so far eluded me?
The issue that precipitated pulling the lower dash panels off is water entry in the R side (passenger) footwell - so far as I can tell, water is dripping down from the center seam of the large round duct encasing the heater blower motor - meaning I likely have years worth of debris plugging up the drain holes in the exterior vent cavities below the windshield and, consequently, rain-water spill-over into my pass. footwell.
Any recommendations as to the best way to unplug the exterior vent drain holes would also be most appreciated.
Thanks, FFF
Name:	P4150019 (75 ppi, letter-size).jpg
Frankenstien is offline
    1973 280SEL Questions etype74 Vintage Mercedes-Benz 15 01-27-2010 08:04 AM
    1973 280sel 4.5 rivman Vintage Mercedes-Benz 7 10-04-2009 07:19 AM
    1973 280SEL 4.5 MBZ300CD Vintage Mercedes-Benz 13 09-03-2006 01:18 PM
    Is this 280sel a 1972 or 1973? ldshull Vintage Mercedes-Benz 8 01-29-2006 07:18 PM
    door parts for '79 280 SEL (116.025) wanted Guest (MBNZ) General Mercedes-Benz 0 02-18-2001 01:14 AM
