Head Gasket or Intake Manifold? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-18-2010, 10:03 AM Thread Starter
Date registered: Mar 2010
Vehicle: '73 280 SE 4.5
Smile Head Gasket or Intake Manifold?
Ok, so I've got some white smoke on my '73 280 SE 4.5. It does not go away and it is a lot of white smoke after start.
I searched smoke and white smoke and read up about possible problems.
After reading I'm pretty convinced it is a head gasket and after reading I do get a lot of white foam in the radiator after idling a bit and revving the engine.
My questions are:
Is there a way to fully determine if its a head gasket?
Is this a pretty difficult job to do on a five scale how would you rate it?
I am a decent mechanic and I like older cars because you can usually work on them if your mech. inclined.
I take my time and take pictures to ensure everything goes back the right way.
Any suggestions on what else it could be causing this white smoke. even though its smoking the car runs surprisingly well I think.
Thanks for any help and suggestions, I think I love this car.
Mario in Fort Worth
FWBenzFan is offline
post #2 of 5 (permalink) Old 04-18-2010, 10:47 AM
Just yank the heads
Mario, if you have ever twisted a wrench you can do this. Realize that this is a periodic maintenance task.
If you commit to do this there are "tricks", like take the exhaust manifolds with the heads. Out and in.
May cost 1K in parts.
Then you get another 150k on the motor.
What is the motor's mileage?
This is a investment in the future.
Brian O
bostosh is offline
post #3 of 5 (permalink) Old 04-20-2010, 10:31 PM Thread Starter
Ok, at the chance of sounding like an idiot. When I changed the oil and filter I put in Castrol 10/30, the smoke started. I changed it again and went with a generic 15/40 and it stopped.
I guess I'm ok? Sounds good and runs pretty decent. I am planning a electronic ignition upgrade.
One question, I did have some white foamy bubbles in my rad. Is this a problem?
I was going to have a radiator shop check the radiator, after I get the aux. fan to operate.
Temp stays at around 175-195 right now. Have yet to here the fan kick on.
Thanks for your replies, I'm excited to learn more about my first Merc V8.
post #4 of 5 (permalink) Old 04-21-2010, 03:26 PM
cadurning's Avatar
Date registered: Dec 2009
Vehicle: '72 280SE barn find
Bubbles in the rad is not a good thing. Does the engine loose water? Is the oil a milky color? Is there oil in the rad? Hopefully the bubbles are a passing thing. If not a head gasket failure is a best case.
There is a kit available for testing the cooling system for the presence of combustion gasses. The one that I have is a device that fits in the filler neck of the rad and has a blue liquid. If the liquid changes color that means that you now have an opportunity to learn about your engine.
If it's not broke it dosen't have enough features.
cadurning is offline
post #5 of 5 (permalink) Old 04-21-2010, 09:02 PM Thread Starter
I will check it to see if I can determine whether it is a gasket or not. Thanks
    Intake Manifold Gasket mdanielson W123 E,CE,D,CD,TD,TE Class 3 03-14-2010 10:34 PM
    2.3L Intake Manifold Gasket Question NoPrayer W201 190-Class 3 03-07-2010 02:27 PM
    380sl intake manifold gasket allis guy R/C107 SL/SLC Class 1 02-20-2010 04:22 AM
    Changing intake manifold gasket Teutone W126 S,SE,SEC,SEL,SD,SDL Class 22 07-28-2009 07:17 PM
    Funky Intake Manifold Gasket benzw00d W201 190-Class 8 05-28-2009 01:42 PM
