The 109 racer - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-15-2010, 07:14 AM Thread Starter
Jackasic's Avatar
Date registered: Jul 2005
Vehicle: 72 280SEL 4.5(airbagged), race cars:88 560 SEL, 74 SLC, 67 200, daily: 99 C43, 06 E55 wagon
The 109 racer
Guess this need it's own thread. I run a 89 Jetta in a series called 24 hours of LeMons The 24 Hours of LeMons After having running that car and building it, I decided I want some MB craziness also. Picked up a 67 200 and now a 72 300.
Plans for the 300 include: manual trany swap, bigger brakes, convert to springs from bags, maybe some regrind cams from Schneider cams, generally race prep (cage, wheels, tires, fuel cell, stripping, ect)
picture of the rust bucket:
Performance parts for w126, r/c107, w201, m117, m119, m102, m104 and few other things.
Reproduction 17" Penta wheels coming soon.
Feind Motorsports
Jackasic is offline
post #2 of 11 (permalink) Old 09-14-2010, 10:21 AM
DoktorNo's Avatar
Date registered: Jul 2006
I want to see this hit the track.
1971 300SEL 6.3
1985 280TE 5spd
1986 190E 2.3-16V
1986 300E 5spd 24hoursoflemons car.
DoktorNo is offline
post #3 of 11 (permalink) Old 09-14-2010, 10:54 AM
Date registered: Apr 2009
Vehicle: Mercedes 280 SE 3.5 coupe, pagoda 230 SL '64, 500 E W124, CE 220 Cabrio, E 320 T W211, w126 6.0 AMG
300 SEL 6.8
If you are interested in a Tremec converson Kit, I know someone who sold it if you want.
Best Pagodino
pagodino is offline
post #4 of 11 (permalink) Old 09-14-2010, 04:52 PM
Date registered: Nov 2008
How did you get a free Mercedes? If I understand right, there is a specific budget within which you can buy and prep the car.
audihenry is offline
post #5 of 11 (permalink) Old 09-15-2010, 05:23 AM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
I can't see well on the trunk lid: is that a 4.5 or a 6.3?
GGR is offline
post #6 of 11 (permalink) Old 09-15-2010, 05:43 AM Thread Starter
Jackasic's Avatar
a 4.5, going to look for a 6.9 our of a 79 if I go that route. it is an endurance racer so I don't want to big of a gas hog.
Feind Motorsports
Jackasic is offline
post #7 of 11 (permalink) Old 09-15-2010, 01:29 PM
M100
This is a stoney way, 6.3 and 4.5 Chassis are different. In which kind of race you will perform? A better solution for you could be a 560 M117 transformation. The european 560 has 300 Din-Hp (340 SAE?) without being touched. The 6.2 M117 AMG version (I am shure they are in USA) is around 385 Din Hp with high torque. The 560 can be adapted to a Getrag 265 or Tremec with some 3.5, W210 and BMW-Parts and will fit straight under the bonnet. In circuit race cars the steal coil system is better for performance but reting with the originale Anti-dive of the 4.5. The 4.5 has the perfekt track Diff-ratio for the 560/500 and the getrag with 5-th 0.87. The motor is less heavy then the original steal m117 and so the servo-steering can be taken off for track use. 6.3 and 6.9 are very heavy engines and costy in mantaince and parts. M119 don't fit, M113 fits like the V12.
best regards Pagodino
pagodino is offline
post #8 of 11 (permalink) Old 09-18-2010, 05:47 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Best Pagodino
I know someone who has a toyota 5 speed conversion. it works well on the M198 but a m100 6.3 will not work well with manual trans because the thrust in the crank shaft wasn't designed to take a load from a clutch.
mercmad6.3 is offline
post #9 of 11 (permalink) Old 09-18-2010, 07:45 AM Thread Starter
Jackasic's Avatar
here are some of the motors I am looking at, thoughts:
6.9: 1979 450 SEL 6.9 MERCEDES PARTS
or a newer 500sl: 1991 mercedes 500SL for parts
I have a 4 speed out of an SL, thought about doing a Tremec 5 speed, dime a dozen around here.
Feind Motorsports
Jackasic is offline
post #10 of 11 (permalink) Old 09-18-2010, 09:35 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Curious ... I was under the assumption that the chassis of the 109s were identical, but the engines differed. Can you offer more info?
Grubeguy is offline
    w126 widebody racer Timsecwide W126 S,SE,SEC,SEL,SD,SDL Class 89 05-23-2011 05:31 AM
    Super AMG R171 racer! Daniel R171 SLK-Class 2 04-20-2006 09:17 AM
    Victor Racer V700's 430 R170 SLK-Class 13 03-05-2005 09:02 PM
    MB Racer... Guest (MBNZ) W201 190-Class 4 12-21-2001 09:00 PM
    SLK 32...drag racer???? Periokid R170 SLK-Class 3 07-23-2001 11:27 PM
