the door locks on my 300D appear to be acting a little strange - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-14-2010, 09:46 PM Thread Starter
sierra1194's Avatar
Date registered: Mar 2004
Vehicle: 1981 300D, 1967 VW BUG
like I'll open the driver side door but the other door locks won't come up until I run the engine a little. I'm told maybe I have a leak somewhere or a 'bellow's" is leaking air due to old age. So is there a link with step by step instructions how I can take apart what I need to to check vacuum lines, and whatever else and replace if necessary. Thanks.
sierra1194 is offline
post #2 of 2 (permalink) Old 04-15-2010, 12:57 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Your car has the vacuum actauted door locks. In each door is small vacuum operated bellows. the easiest solution is to remove each door lining and check the operation of the bellows. The fuel door and trunk lid also have the same set up. You need to do a bit of exploring in the trunk to find the leaky bellows .
Under the hood,the yellow lead going into the fireqwall from the engine compartment is the main vaccum line .make sure it is secure and hasn't come adrift anywhere.
mercmad6.3 is offline
    door locks acting up urquell W201 190-Class 1 06-12-2007 09:35 PM
    door locks acting weird aless W163 M-Class 4 05-21-2007 03:42 PM
    help my door locks are acting up chicagoml55 W163 M-Class 14 03-03-2007 03:15 PM
    Ignition W/key + Front Door Locks 1983 300d panamacolin For Sale/Wanted/Trade/Giveaway 4 01-09-2007 04:13 PM
    DOOR LOCKS ARE ACTING UP PLEASE HELP...... chona W163 M-Class 11 12-25-2004 09:59 PM
