76 W115 300d shifts late - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-13-2010, 04:39 PM Thread Starter
RobnGloria's Avatar
Date registered: Apr 2010
Vehicle: 1976 300d w115
Just bought a 1976 W115 300d and it is shifting a little late. Also the engine keeps running after I turn it off sometimes. I think it might be the vacuum valve but I am not sure where it is located. I read I can adjust it to make it shift earlier or later but I am not sure how. Any help would be great. Other than that she runs like a champ and Its probably the best car I have ever owned. Thanks for any advice and happy driving!
Rob and Gloria
RobnGloria is offline
post #2 of 2 (permalink) Old 04-13-2010, 06:18 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
Yes you can adjust shift points, on the passenger side of the motor down under the exhaust manifold you will see a pivot with 2 pieces of linkage connected to it. Take loose the piece of linkage closest to the motor and make it shorter(might be longer can't remember). Just play around with it the linkage length until it shifts like you want it.
Sounds like you have a vacuum leak somewhere. Just start blocking off circuits until you find the leak. Check the shut-off valve on the back of the injection pump, it should hold vacuum.
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
    1995 E300 Diesel Auto Trans Shifts Late arghknork W124 E,CE,D,TD Class 1 01-15-2011 09:01 AM
    W115 300d questions Cefalu Vintage Mercedes-Benz 1 04-06-2010 08:20 AM
    87 300D-Transmission-Hard shifts Lemosx4 W124 E,CE,D,TD Class 1 05-20-2009 07:50 PM
    car shifts to 2nd late when engine is cold johnny007 General Mercedes-Benz 2 03-15-2008 12:16 PM
    Help Please, w115 300D smemolo For Sale/Wanted/Trade/Giveaway 0 12-18-2006 11:38 PM
