Some play in steering arm relay '62 W111 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-06-2010, 07:29 PM Thread Starter
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 11 Post(s)
Hi all,
the other day I checked the play in the steering linkages and noted that the steering arm relay has some play on the lower part of the shaft. EPC doesn't show any bushing to be replaced there for the 111021 model (later models are different) but there is a repair kit for the W113 230 SL with a bushing which is a 111 part number (111 460 00 50). By running the number into EPC it also applies to the 111021.
I would like to know what is involved before ordering that repair kit: is there some machining required to fit what looks to be a brass bushing where there is none originally? If yes, is the machining required on the shaft or on the part welded in the firewall?
GGR is offline
    Play in pitman arm/steering box shaft connection Turbodrive W124 E,CE,D,TD Class 3 04-26-2014 06:32 PM
    W111 Steering Wheel Horn Adjustment alydon Vintage Mercedes-Benz 9 07-13-2013 10:25 AM
    WANTED: Power steering for W111 '61 sedan bens280e For Sale/Wanted/Trade/Giveaway 0 06-22-2009 05:22 AM
    W111 Coupe power steering box problem GGR Vintage Mercedes-Benz 3 03-04-2009 05:14 PM
    W111 Steering Wheel removal alydon Vintage Mercedes-Benz 2 03-09-2008 02:57 PM
