1974 206D Glow Plug Questions - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-06-2010, 10:45 AM Thread Starter
Date registered: Apr 2010
Hello, a few friends and I own a 1974 Mercedes 206D Camper Van. It has a OM615 engine in it. From what I can tell it has all the engine/starting/glow plug set up as a 220D. Here is my question: the starter/glowplug pull switch broke. It no longer turns on the glow plugs or engages the starter. I pulled the switch out and tested it and it is no good. I already hooked the starter up to the Key switch but I need to know how to run the glow plug circuit. I would like to run the glow plugs on a separate switch. Can I just run 12volts to the rear glow plug? Under the dash I can see some kind of resistor? (white porcelain with a coil of wire running across), this is some how wired in the glow plug circuit. If someone is familiar with this glow plug system I would appreciate some advice or a diagram.
Thanks
Cody
studebakerman2001 is offline
Glow plug(s) or glow plug relay...? kavakava W123 E,CE,D,CD,TD,TE Class 16 03-04-2010 07:45 PM
Late Glow glow plug relay smallfence W123 E,CE,D,CD,TD,TE Class 16 10-21-2009 06:33 PM
DIY Glow plug relay and Glow plugs 240Dbio W123 E,CE,D,CD,TD,TE Class 17 06-18-2009 03:38 PM
Glow plug problems, no power to the glow plug relay kbbenz78 W123 E,CE,D,CD,TD,TE Class 8 11-15-2006 08:45 PM
glow plug light only comes on when 5 pin plug is disconnected from relay JLincoln W123 E,CE,D,CD,TD,TE Class 5 11-20-2005 04:58 PM
