68 280se fuel issue? Help - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-01-2010, 02:15 PM Thread Starter
Date registered: Apr 2010
Vehicle: 2001 E430, 1987 560SEC, 1968 280SE
Hi guys, Just bought a 68' 280se. I think I have a fuel pressure problem but need to be sure. Psi out of the rear pump is minimal. No gauge to give actual number but barely pissing.
Near as I can tell by searching this forum, I think I should have 15+psi?
If this is correct, I think I know the issue but need some verification on that rear pump's pressure.
Thanks
Derek
dtek is offline
post #2 of 3 (permalink) Old 04-01-2010, 02:39 PM
cadurning's Avatar
Date registered: Dec 2009
Vehicle: '72 280SE barn find
Yep it's 15psi. The flow is also an issue about 1 gallon per min at the return to the tank.
If it's not broke it dosen't have enough features.
cadurning is offline
post #3 of 3 (permalink) Old 04-01-2010, 03:47 PM
Date registered: Jun 2004
Quoted: 17 Post(s)
Sounds like a blockage from the tank. If the pump actually moves fuel it will be OK.
If you can get a minimum of 10 PSI, that will be enough pressure but volume is the critical factor.
It's 1 liter in 15 seconds measured at the cold start valve.
mercmad6.3 is offline
electrical issue on 1970 280SE edroth17 Vintage Mercedes-Benz 2 07-28-2008 07:20 PM
Hot start issue, 79 280SE rabbit188 W116 S, SE, SEL, SD Class 11 10-22-2007 01:20 AM
Fuel filter before or after fuel pump on 1972 280SE? Floydf Vintage Mercedes-Benz 6 10-19-2006 09:09 AM
metal fuel line CIS fuel injection 79 280se w116 rfitts46 W116 S, SE, SEL, SD Class 0 01-28-2006 02:37 PM
78 280SE Mutiple Idle/start issue...Related? wdba123190 Vintage Mercedes-Benz 5 07-06-2004 02:31 PM
