OM617 making strange noises... - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-31-2010, 08:24 PM Thread Starter
TeflonFetus's Avatar
Date registered: Aug 2009
Vehicle: '85 300D - 381K and increasing daily
Send a message via AIM to TeflonFetus
okay, this is probably obvious to many of you but i want to make sure before i spend a good chunk of time and money fixing anything...
noticed a ticking sound that got much louder in a short amount of time, right after a road trip during which the engine was running at highway speeds for 31 hours straight. thought it was valves on no.1; pulled valve cover and found a somewhat loose timing chain, grooved guides flaking plastic everywhere and a tensioner at the end of its travel. sound is coming from IP/vac pump/idler gear area. went in with a stethoscope but can't pinpoint it exactly. changed the tensioner and it got louder (oops...)
pushing 375K on stock everything...compression's good, injectors are cleaned and pop tested, trans is best i've ever had on any car...it's worth fixing. assuming its the chain...can it tick/click like that? it also does it during cranking before it fires, which takes a while, and is accompanied by large clouds of smoke, im assuming from the nearly 10 degrees of stretch it has on it.
so assuming its the chain (input please?), i've read all about it and want to make sure im not missing anything. the tensioner doesn't have a spring on N/A models apparently...dieselgiant's chain kit seems a bit overpriced...brand recommendations and the like would be nice. i don't want any cheap chinese junk on a swiss watch of a motor.
'83 300DT -- 284K (rust casualty-gone in 2009)
'76 W115 300D -- spun bearing at 400K+, RIP 10/31/12
'78 300CD -- 159K - sold or crushed by ex (cringe)
'83 240D -- 162K - totalled (not by me) (parts car)
'75 240D -- 91K - clean enough to eat off the frame
'85 500SEL Euro -- 196K - why not?
'85 300DT --
03/16/10 - 243K
05/30/14 - 381K (daily driver - it won't die!)
TeflonFetus is offline
post #2 of 2 (permalink) Old 04-01-2010, 05:09 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 131 Post(s)
Chain tensioner does have spring (158). Something needs to keep tension until oil pressure arrives. Remove vacuum pump and inspect lever with bearing. Inspect cam plate that drives vacuum pump.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
Gas Tank Making Noises in Trunk sammywater W124 E,CE,D,TD Class 4 08-20-2009 07:19 AM
below 60 car is making loud noises joeygambino W124 E,CE,D,TD Class 1 09-13-2007 05:09 PM
ML making crazy noises.. Please help!! josh64fx W163 M-Class 12 06-02-2007 02:36 PM
Power steering making noises w140benz W123 E,CE,D,CD,TD,TE Class 0 11-10-2005 04:25 PM
My Ml is making cracking noises!!!!!! Darkmann W163 M-Class 8 07-20-2004 10:22 PM
