fuel pump - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-27-2010, 11:20 PM Thread Starter
Date registered: Oct 2009
Vehicle: w111 3.5 coupe
fuel pump
my garage says that the the pipes and also the fuel pump its self is leaking
i just smelt a strong gas smell so thats why i took it to get chked
i was wondering what does the fuel pump do and what if it doesn't work well how does it effect the car
i will replace it offocurse but just want to know this info
ds58 is offline
post #2 of 4 (permalink) Old 03-28-2010, 08:09 AM
Date registered: Apr 2008
Quoted: 2 Post(s)
If you're smelling fuel, obviously there is a leak somewhere and the vehicle should not be driven any longer until the source of the leak is found and repaired. It could be an extreme fire hazard. The fuel pump pumps fuel from the gas tank to the carburator or fuel injection system. If it completely quits working, the vehicle won't run any longer. With that in mind, it could be something as simple as a leaking rubber fuel line somewhere in the system. This would be quite inexpensive. If the fuel pump is bad, it will be a little more costly, but should not break the bank. Have your mechanic show you where the leak is so that you can observe it first hand, and then decide your course of action.
mbbuff is offline
post #3 of 4 (permalink) Old 03-28-2010, 12:02 PM Thread Starter
thanks for your help
ds58 is offline
post #4 of 4 (permalink) Old 04-01-2010, 03:52 PM
Date registered: Jun 2004
Quoted: 5 Post(s)
You have a very desirable car ( W111 3,5 coupe) . Make your mechanic order a new pump and the correct rear fuel lines from mercedes and make 100% sure he replaces ALL of the rubber fuel lines on the engine. This a Djet equipped engine and the fuel runs at 28 PSI (2bar) . The fuel pressure can cause Old lines to burst and the car to catch fire. I have seen plenty of leaky hoses on Djet Equipped mercedes so your situation is normal.
mercmad6.3 is offline
    Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 15 03-04-2012 08:52 AM
    1988 260e w124 no fuel...changed fuel pump and relay!! salthepal W124 E,CE,D,TD Class 11 01-07-2012 08:32 AM
    fuel air mix / testing fuel pumps and pump pressure william.wood W126 S,SE,SEC,SEL,SD,SDL Class 0 11-09-2005 11:32 AM
    380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 03:44 AM
    Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 04:47 PM
