rebuilding my radiator brings up a ? on engine oil cooler - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-16-2010, 11:43 PM Thread Starter
Date registered: Sep 2009
Vehicle: 72 280 se 4.5 and a bunch of other german cars
car- 72 280 se 4.5
i developed a tiny pin hole on my upper radiator. My initial plan was to rip the rad out and braze the hole shut --quick and easy to keep it on the road until i needed to do more complex surgery. Once i had the rad out though, some fins were looking weak showing green. For as many miles as i put on the car, it is just a matter of when it will blow out. Rather fix it now than have it blow out on me while making a 600 mile trip.
So my plan snowballed out of control already. Time to do a radiator rebuild w/ an all new copper core and clean up the end tanks/reassemble the rad. That's no issue and parts are coming in for the surgery.
Now that the rad is apart--i can look further into a second issue--the engine oil cooler. My engine oil cooler is not hooked up--this is how i received the car from the previous owner. the lines are capped off at the engine. what was-- if any-- common fail point of the engine oil cooler setup? My initial thought was one of the threads were stripped on the cooler or it physically leaks. Yet the cooler has pressure checked out and threads are nice. Maybe i have a rare instance of 1 line went bad, so both were blocked off until a later fix that never materialized. yet that seems to good to be true. Sorry im not to familiar w/ the fail issues of these cars. As the car is 8 years older than I.
thanks for insight
mike
mtkst19 is offline
post #2 of 6 (permalink) Old 03-17-2010, 05:35 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 97 Post(s)
There was never any particular problem with oil cooler setup. Once every 20 years you replace hoses.
14 116 187 06 82
17 116 187 05 82
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #3 of 6 (permalink) Old 03-17-2010, 04:14 PM Thread Starter
thank you for the reply back. just the info I needed pertaining the failure--if any. so good chance mine may have failed via normal wear and tear and simply never replaced.
i can get both lines through imc or worldpac w/ ease.
One more question for you-- the illustration you posted w/ part numbers. How do i obtain the software to look up numbers myself? I have similar programs for vw/audi/porsche/bmw. Yet nothing for mb. I think that would be beneficial for me to have.
Thanks
Mike
mtkst19 is offline
post #4 of 6 (permalink) Old 03-17-2010, 04:31 PM
zeddies's Avatar
Date registered: Feb 2009
Vehicle: 1979 450 SEL
I think it is called EPC:
EPC
1979 450 SEL "Spinne Blaue"
zeddies is offline
post #5 of 6 (permalink) Old 03-17-2010, 08:54 PM
Witek_M's Avatar
Quoted: 97 Post(s)
Thanks
Mike
If you live in North America you can sign up for EPC at: EPC-net Online - Subscription Step 1 of 3
BTW take some time to update your profile with location and vehicle info.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #6 of 6 (permalink) Old 03-17-2010, 10:47 PM Thread Starter
thanks for the link. i signed up. will have to sit down and play with it to get the hang of searching for parts.
mtkst19 is offline
    W126 Engine Oil Cooler AxelWulff W126 S,SE,SEC,SEL,SD,SDL Class 5 07-10-2012 03:08 PM
    Using the trans oil cooler at the bottom of the radiator as an engine oil cooler GGR Vintage Mercedes-Benz 6 06-08-2009 01:15 PM
    Will additional oil cooler help preserve engine and enhance performance? eddietham R170 SLK-Class 11 02-14-2008 02:27 PM
    Engine hot, Oil cooler cool??$$%$$%^ hotwheelbill W123 E,CE,D,CD,TD,TE Class 7 10-04-2006 04:04 AM
    Radiator Replacement, Oil Cooler, Viscous Fan Clutch ericgr R/C107 SL/SLC Class 1 09-18-2004 10:38 AM
