62 220 SEB axle boot - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-11-2010, 03:18 PM Thread Starter
Date registered: Sep 2009
I'm in the process of repairing all the leaks in the rear axle of a 220SEB (W111).
I've replaced the leaking outer seals and bearings, while I have the passenger side apart I intend on replacing the swing axle boot as well, with a stock boot, not a stapled one.
Anyone ever do this? I'm at the point of removing the axle tube from the diff to move it back far enough to slip a new boot in. Is there an easier way? Other than removing the pivot bolt and sliding the whole tube off?
Any advice would help!...for some reason the factory books I have are missing that entire section ...
MechSB is offline
post #2 of 4 (permalink) Old 03-12-2010, 05:32 AM
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 11 Post(s)
I'm right in the middle of rebuilding a rear axle.
While you are there you should assess the condition of the rubber mount connecting the pin to the upright arm. This mount is made of rubber in the middle of two metal sleeves and deteriorates with time, grease and oil. Replacing it as well as the donuts in front of the trail arms, bushings at the back of the trail arms and the center mount in the boot usually transforms the ride of the car. While you are there you should also check the journals on the wheel tube in which the pin goes for scoring.
Don't forget to take the small pin (doesn't know the term in English, but it's like the one used on bycicle pedals) before removing the main pin, otherwise it won't come out.
GGR is offline
post #3 of 4 (permalink) Old 03-12-2010, 06:49 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Not sure if the fintail boot is exactly the same as the ponton, but here is a write up I did for the ponton - Mercedes-Benz Ponton Rear Axle Solid Boot Replacement © www.mbzponton.org
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - for sale - http://www.benzworld.org/forums/w123...g-my-240d.html
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
post #4 of 4 (permalink) Old 03-12-2010, 08:22 AM Thread Starter
Thank you both for the advice!
I'll take a look at your writeup for sure Sokoloff.
Have a great weekend both of you!
MechSB is offline
    How to go about selling my 61 220 SEb coupe kaaprok Vintage Mercedes-Benz 4 07-27-2009 06:17 PM
    MB 220 seb that sat for 30 yrs livinthe50s Vintage Mercedes-Benz 5 04-13-2009 10:32 AM
    220 SEB Differential heckflossehappens Vintage Mercedes-Benz 9 09-26-2008 05:43 PM
    220 SEB Converting to Carburator 220SEBC Vintage Mercedes-Benz 26 09-13-2008 09:38 AM
    1961 220 SEb/c - Thoughts? goldgunner Vintage Mercedes-Benz 4 08-23-2005 08:08 AM
