A/C used to but doesn't keep cold anymore - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-11-2010, 02:19 PM Thread Starter
sierra1194's Avatar
Date registered: Mar 2004
Vehicle: 1981 300D, 1967 VW BUG
I live in So Caliifornia and need my A/C. It used to be really cold but nada. I was advised and had it converted from the old system? to R134A, replacing a receiver/drier, pressure switch and it was charged up with new refrigerant.
1) Air blows, but it isn't cold at all as if the refrigerant leaked away. My current mechanic charged up the refrigerant for me and it was fine when I drove away. Come summer, nada, no cold air at all. Is a compressor leaking or needs to be replaced? Loose lines somewhere? Other possibilities?
How should I go about checking this out.
2) No air comes out of the center vents either.
sierra1194 is offline
post #2 of 3 (permalink) Old 03-11-2010, 03:08 PM
Date registered: Sep 2009
If you don't have pressure gauges then you'll need to take it back to the mechanic that converted it. Or if you don't like him anyone that can work on A/C.
You'd need the gauges to diagnose the system, the center vents not blowing air is another, separate, problem.
Good luck!
MechSB is offline
post #3 of 3 (permalink) Old 03-11-2010, 07:44 PM
Date registered: Apr 2008
Quoted: 2 Post(s)
You're probably going to continue to have problems with this setup. I've tried the conversion from R12 to R134 on another vehicle (non MB) and ended up having to replace everything. First the R134 requires a significantly higher pressure to cool properly, and if you have an old tired York compressor, it may not cut the mustard. If you don't want to spring for R12 there are several replacements available for this freon. I used Freeze 12 and it works more like R12, but still not quite as cold. Let us know what comes of this. I know you need real cooling down there. On my Benz I also put in all electric fans, as with the A/C on I used to heat up in traffic before. I am using a 16 in. in front of the radiator (replacing the stock one) and use a thermostatically controlled 14 in. in place of the stock water pump driven clutch fan. I've had this setup for almost a year now and so far it seems to be working quite well. I've also got them set up so all fans are running anytime the A/C is on, in addition to having the front one come on with the 100 C switch on the engine.
mbbuff is offline
    Cold, COLD starts. Emergency cold start tips? n23ova W123 E,CE,D,CD,TD,TE Class 24 11-09-2011 05:27 PM
    frozen toes, lower vent blows cold cold air when heat is on?? mbnz230 W202 C-Class 3 05-31-2011 02:17 PM
    Justice is a dish sometimes served up cold or at least with a side of cold metal tool Jakarta Expat Off-Topic 6 01-15-2008 10:54 AM
    AC will not blow cold air anymore moose300d W163 M-Class 5 05-14-2006 08:07 PM
    I just cant take it anymore!! 300Diesel W123 E,CE,D,CD,TD,TE Class 3 10-18-2005 06:31 PM
