Problems removing neutral safety switch from 72' 250c - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-09-2010, 10:25 AM Thread Starter
Date registered: Jan 2007
Can someone tell me if I need to drop the transmission on my 1972 250C to remove the neutral safety switch. I tried to remove the NSF but there is not enough clearance between the gear selector shaft coming from the transmission and the floor panel for the NSF to come off. It seems the shaft is about 1/2" too long to remove the part. This doesn't seem right to me as I'm sure this part was designed to be removed without heavy work involved. Any advice would be appreciated.
robinmcdowall is offline
post #2 of 2 (permalink) Old 03-11-2010, 03:26 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
If it's too close it sounds like an engine mount has collapsed too. Undo the trans crossmember and use a hydraulic jack to lower the rear of the trans slightly . This will allow the switch to come off the trans. You can also fit the new shifter bushes easily at the same time.
mercmad6.3 is offline
    Neutral Safety Switch/Backup Light Switch SC Surfer W123 E,CE,D,CD,TD,TE Class 13 01-18-2008 01:45 PM
    safety/neutral switch userpaul5237 W116 S, SE, SEL, SD Class 1 08-14-2006 08:28 PM
    starter/neutral safety switch problems? benhamin2 W124 E,CE,D,TD Class 6 12-24-2005 03:32 PM
    problems with a neutral safety switch Ernest T Bass W124 E,CE,D,TD Class 0 02-21-2005 10:14 AM
    560 SEL neutral safety switch problems. Valv W126 S,SE,SEC,SEL,SD,SDL Class 2 11-22-2003 12:30 PM
