1975 280C question - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-28-2010, 05:09 PM Thread Starter
Date registered: Feb 2010
Vehicle: 1975 280C
1975 280C question
Hello, I forgot to ask this in the previous post. The horn and wipers on on the same fuse but when I changed it, it blew out immediatly. What could be the problem? A short somewhere? Where would I look to fix this?
Also, does anyone have a diagram of everything under the hood? Or even just a vacuum diagram?
BTW, I posted earlier today with questions about my seatbelts and some other things. I put several pics in there too...just incase you wanted to check that out and help me.
Thanks,
Kayla
KaylaMick is offline
post #2 of 4 (permalink) Old 03-02-2010, 06:46 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
If your new fuse blows instantly, than there is a short somewhere. You can test it by disconnecting all wire from the fuse and connecting them one by one. Than you know which causes the problem. If you have a multimeter you can test it too.
Most likely it is the horn, but it could be in the wipers too.
Govert70227 is offline
post #3 of 4 (permalink) Old 03-09-2010, 10:22 AM
dega's Avatar
Date registered: Mar 2010
Vehicle: W123 - 1979
You can try to detecting the short connection one by one. The easy way is disconnect the wiper rotor cable. If your fuse is not bow up, then just there some short connection. If still blewn up, then try to disconnect the horn wire and try the previous step, so you can make sure one or both between horn or/and wiper that has short connection.
Hope helpfully
W123 280 1979
W115 200 1976
W124 300E 1991
dega is offline
post #4 of 4 (permalink) Old 03-09-2010, 11:02 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
The most likely culprit is the horn. I had the same issue, and it was a quick fix (I would later buy new horns from eBay).
Grubeguy is offline
    new member 1975 280c Always General Mercedes-Benz 4 02-21-2010 12:29 AM
    Value of 1975 280c rgm Vintage Mercedes-Benz 7 06-06-2007 06:13 AM
    For Sale: 1975 280c thatpatgirl For Sale/Wanted/Trade/Giveaway 0 07-14-2006 12:27 PM
    1975 280C Driveability vs. Original dawallace Vintage Mercedes-Benz 2 02-15-2006 07:18 AM
    1975 280C M110 Miamisun Vintage Mercedes-Benz 2 06-06-2004 01:17 AM
