Hard start 300d with only 208K - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-25-2010, 12:15 PM Thread Starter
87300d's Avatar
Date registered: Feb 2010
This is the second time this has happend in about 6 months. Went to start my Daily driver 87 300D. Crank crank and crank nothing. Drained battery, charged it then it started only with the pedal to the metal. Engine heater was plugged in, glow plugs are fine. What going on?
I was thinking injectors?
Also every now and then I will add some 2 stoke oil mix to the tank, just a little of Golden Spectro mix, it runs nice and quiet when I do so. Will this hurt?
87300d is offline
post #2 of 2 (permalink) Old 02-25-2010, 11:58 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
I think you have more success with your question in the W124 forum.
Your car is designed to run on diesel, not on two-stroke oil. Quieter running doesn't necessarely mean better running.
Govert70227 is offline
    82 300d HARD/WILL NOT start homeboyjohn_96 W123 E,CE,D,CD,TD,TE Class 11 01-22-2010 07:01 AM
    0w-40 no longer avaliable anywhere I look... recommended weights? Midwest, 208K miles HACK THT W163 M-Class 32 10-26-2009 07:38 PM
    300D hard to start when cold Greg A. W124 E,CE,D,TD Class 9 03-14-2007 05:51 AM
    300D hard start saga... Advice? DieselDave W123 E,CE,D,CD,TD,TE Class 3 01-12-2005 05:27 AM
    Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 06:23 PM
