1976 450sl cam alignment marks? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-24-2010, 07:09 PM Thread Starter
Date registered: Feb 2010
I just got this 1976 450sl from a friend that needed money and he was in the middle of a head job. I know the process of putting the engine back together but the cams were not marked and I don’t know where to align the cams? I see the grove were the key is located on the cam washers and I see two marks on the first cam bearing holder; one were the oil tube is and one a little below that. I am needing to know where to align the cams to put the timing chain on? Any assistance would be greatly appreciated. Thanks.
f72gts429 is offline
post #2 of 2 (permalink) Old 02-25-2010, 03:52 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Got a valve spring compressor for a mercedes V8?
If you have one,remove the rocker arms ,then set the crank to number one top dead center by the marks on the damper. Then turn the cams so the groove on the washer behind the cam gears lines up with the raised line on the number one cam tower on each head. As long as the chain and chain tensioner are new the marks should line up OK. I remove the xchain wheels when doing this so i can turn the cams and line them up,then just fit drape the chains over the gears and pop them on,refit the tensioner and wind the engine over to make sure everything is OK.
mercmad6.3 is offline
    Cam Timing Marks on 1984 380 sl Tony Barroso R/C107 SL/SLC Class 17 03-10-2014 03:40 AM
    C36 m104 engine cam timing marks?????? sime.nac W202 C36 AMG, C43 AMG 1 04-27-2009 07:00 PM
    Alignment Marks on Steering Box? donniej W123 E,CE,D,CD,TD,TE Class 6 06-07-2006 07:12 AM
    Cam riming marks for Mercedes 190 D Guest (MBNZ) W201 190-Class 1 07-03-2001 05:08 PM
    Cam riming marks for Mercedes 190 D Guest (MBNZ) W201 190-Class 0 12-17-2000 09:29 AM
