Do I need to compress the front springs - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 02-23-2010, 06:58 PM Thread Starter
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
I need to replace the upper eccentric pins and bushings (upper A arm to King Pin) in my 72 280SEL 4.5 due to excessive play. King pins seem fine. Do I need to compress the front spring prior to breaking this joint or is there a better way? The MB manual talks about a special tool that goes in place of the shock, but I can't find what this tool looks like. Any help is appreciated.
TZ_280SEL is offline
post #2 of 12 (permalink) Old 02-24-2010, 12:43 AM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 18 Post(s)
Nutz 4 Benz is offline
post #3 of 12 (permalink) Old 02-24-2010, 06:46 AM
I do these one side at a time by placing the floor jack below the spring and using the weight of the car to keep the spring compressed. then just swap it out, hopefully the eccentric bolt has not seized. Center the new one and don't forget the rubber seals.
Brian O
bostosh is offline
post #4 of 12 (permalink) Old 02-24-2010, 09:57 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
I removed my front springs using a floor jack and unbolting the lower control arm and lowerering down the control arm. It was the scarriest time of my life!
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #5 of 12 (permalink) Old 02-25-2010, 03:57 AM
Date registered: Jun 2004
Quoted: 17 Post(s)
If the rubber stops under the upper Control arm are good,you need to use a regular spring compressor to clamp the Arm to the spring ( one each side ) . Use them to pull the arm down against the spring other wise you will never get the king pin and arm back together. As the others have said,use a GOOD jack under the lower control arm.
mercmad6.3 is offline
post #6 of 12 (permalink) Old 02-25-2010, 05:17 AM Thread Starter
TZ_280SEL's Avatar
Quoted: 39 Post(s)
Red face
Thanks for the advice. I'm in the beat, soak, twist repeat mode right now. After 24 hrs of soaking, the eccentric bolt finally turns. Hope to get it free enough to remove this weekend.
post #7 of 12 (permalink) Old 02-25-2010, 07:39 AM
Mercmad has a good idea for safety clamping, and good jack
I've had the bolt break
and the bushing seize into the kingpin.
Hopefully yours will release
Keep them greased,
install bolt with antiseize on the bolt and bushing bore.
Brian O
bostosh is offline
post #8 of 12 (permalink) Old 02-25-2010, 08:08 AM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
You need some sort of clamping !!
Just using a jack, is just plain stupidity..
On some models you can fix a M20 threaded pin through the spring.. But not on all models. Get a proper spring clamp that fits, so you can be sure not to break your jaw or scull..
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #9 of 12 (permalink) Old 02-26-2010, 01:18 PM
Date registered: Aug 2009
Vehicle: 1970 300SEL 6.3 & 1994 S320
Originally Posted by Nutz 4 Benz View Post
This pictured tool is for compressing springs and for sale on Ebay for less than $200. Don't take the chance of the spring flying out and causing damage or injury.
kimoclutter is offline
post #10 of 12 (permalink) Old 02-28-2010, 12:56 PM
Date registered: Apr 2008
Quoted: 2 Post(s)
Just be real careful, as if it gets away from you it can really do some damage. A compressor is the best way by far.
mbbuff is offline
How to compress front springs W115 Eirik 400 SE Vintage Mercedes-Benz 2 09-03-2008 02:13 AM
Front Springs Versace W210 E50 AMG, E55 AMG 3 07-21-2007 05:13 PM
front springs - Help bushbenz G-Class 1 08-28-2005 09:35 AM
NEW FRONT SPRINGS MAYBE ???? Smokiesman W124 E,CE,D,TD Class 8 03-20-2005 07:06 PM
air condition compress replace roempty W123 E,CE,D,CD,TD,TE Class 4 06-11-2004 06:39 AM
