Do I need to compress the front springs - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 03-02-2010, 07:15 AM Thread Starter
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 34 Post(s)
Thumbs up
I appreciate all the feedback. I am a belt and suspenders kind of guy, so I have a spring compressor and jack and stands for this job. The eccentric bolt on the passenger side was frozen to the bushing, but the bushing would turn. Saws-all took off the washers, backed the entire assembly out as one piece and replaced upper and lower bushing. Drivers side eccentric bolt came out, but bushing was frozen to kingpin. Had to remove the entire spindle and king pin. Used a mini hacksaw to cut two notches in the bushing down to the threads and then about an hour of beating with a 3# maul and a cold chisel. I finally won and the new bushing is installed. She should drive much better once I get her aligned. Thanks for the help.
TZ_280SEL is offline
post #12 of 12 (permalink) Old 03-03-2010, 06:12 AM
wbain's Avatar
Date registered: Dec 2003
The Klan spring compressor will not work on that chassis. It's for W124's, W116 and W126.
wbain is offline
    How to compress front springs W115 Eirik 400 SE Vintage Mercedes-Benz 2 09-03-2008 02:13 AM
    Front Springs Versace W210 E50 AMG, E55 AMG 3 07-21-2007 05:13 PM
    front springs - Help bushbenz G-Class 1 08-28-2005 09:35 AM
    NEW FRONT SPRINGS MAYBE ???? Smokiesman W124 E,CE,D,TD Class 8 03-20-2005 07:06 PM
    air condition compress replace roempty W123 E,CE,D,CD,TD,TE Class 4 06-11-2004 06:39 AM
