Static timing on a 70 280SEL? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-23-2010, 03:09 PM Thread Starter
Date registered: Jun 2006
Vehicle: 2003 230 Kompressor, 1970 280SL, 1991 300SL, 1970 SEL Limo
Does andybody know the static timing number for a 70 280SEL M130. (Can't find my BBB) I sort of remember it being 10 deg BTDC, but am not sure.
Thanks
Michael
Michael C is offline
post #2 of 2 (permalink) Old 02-23-2010, 04:15 PM
It should start well when all the marks align
Set crank pointer static at 0-10 maybe 5
(both valves closed compression stroke)
rotate distributor body mark to align with mark on rotor,
(you can even can listen for spark while rotating body)
Close enough to run, use a timing light after running.
Brian O
bostosh is offline
    300D 87 Diesel Injection timing or Cam timing? davidknaus W124 E,CE,D,TD Class 2 01-10-2009 03:27 PM
    Timing Chain or Timing Belt on 230 Kompressor ? Bal C208/A208 CLK-Class 0 11-21-2005 01:08 PM
    Static in my new HK endodoc Audio & Telematics Forum 3 08-08-2005 03:16 AM
    OT: Static-X DEATHERAGE R170 SLK-Class 0 06-14-2005 11:16 AM
    Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 02:03 PM
