help with start up and coil - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-21-2010, 06:03 PM Thread Starter
Date registered: Apr 2009
So stupid me I left the ignition on in my finny for 2 hours. The ignition coil is just smoldering hot. Now here is the problem. I try to start it today for the hell of it and no go. I charged up the battery and it cranks over and I am gettin fuel. Did i burn out the ignition coil? Because there is fluid coming out of it. Smells like battery acid and the wire on top which connects to the distributor, took it out from the coil and it like soaked with whatever substance! Does it need replacement, is there a way to test it? help
eclipse_22 is offline
post #2 of 3 (permalink) Old 02-22-2010, 04:01 AM
PrivMessage me I have a pile of good used cheap coils.
Do you have a volt /ohm meter ?
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 02-22-2010, 05:14 AM
Date registered: Aug 2009
Quoted: 49 Post(s)
It's junk. Replace it.
Mike D is offline
    Anyone have a used coil? mckellyb W124 E,CE,D,TD Class 2 10-17-2009 07:12 PM
    New plugs, wires, ignition coil and still no spark from new coil? rmariscal W203 C-Class 6 07-18-2009 06:18 AM
    Part # A0004640318 'reed coil' 'spring coil' pokdub General Mercedes-Benz 4 02-02-2008 05:42 PM
    HD rear coil springs vs standard coil springs crash1 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-09-2006 09:11 PM
    where is my coil CivicTuning2 W126 S,SE,SEC,SEL,SD,SDL Class 13 12-21-2005 08:23 PM
